Question about Bowflex Treadclimber
The tracks do not work. it shows E5-5 in the timer box
  • ystepnoski Mar 16, 2009
    tracks are not working error code 5....HELP!!
  • Anonymous Mar 30, 2014
    Display is showing e5 P
I have an error code Err L5 this happened after my machine main power has been turned off.
Posted on Nov 09, 2009
I have a leviton programable timer no.vpt24 Your instructions show two wires in the junction box. I only have one wire.I can join the black to black white to white but no wire to join with red wire
I think you are saying that you have 1 romex-cable entering box.
And that 1 cable has a black, white and bare ground wires.
Here's how to wire Leviton's vpt24 timer.
Timer has Red Black White and Green wires.
Connect White and Green wires to bare ground wire.
Connect Black-timer wire to black wire inside box
Connect Red-timer wire to white wire inside box.
Turn power ON, and try timer.
If timer does not work, then reverse Black-timer and Red-timer.
Here is photo of similar wiring using Intermatic timer
http://waterheatertimer.org/images/EI210-wiring-full.jpg
Below is copy of manual:
http://waterheatertimer.org/pdf/VPT24-single-or-3-way.pdf
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 02, 2011 | Hammering
I have a 4003 osz time clock and it does not turn lights on and off. Where can I get new insides for the same box.
As of November 2010 or before, Paragon is no longer making timers or parts except Defrost timers.
4003 0SZ is not a defrost timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
0SZ suffix appears to be 120Volt astronomic time clock that turns ON at Dusk and OFF at Dawn
4003 is DPST 120Volt 40 amp mechanical timer
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
Tork shows 120volt mechanical Astronomic time piece
7200Z DPST
http://waterheatertimer.org/pdf/7000Z-series-wiring.pdf
http://waterheatertimer.org/Tork-timers-and-manuals.html
MR Supply sells 7200
Intermatic mechanical astronomic clocks:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/astronomic.aspx
These time clocks are Indoor-outdoor and can control 3 different 120V Loads, for example store light in front, outdoor light in back, and outdoor sign. All Loads turn on-off at same time.
Beverly Hills shows the V4547r
Intermatic also makes electronic astronomic time pieces where voltage is selectable, with many timing options (programming is detailed and complicated):
http://www.intermatic.com/products/timers/electronic%20time%20switches/astronomic%20electronic.aspx
NEMA1 is indoor box
NEMA 3R is indoor-outdoor box.
SPST means timer can control 1 Load
SPDT can control 2 120V Loads
1000 Bubs sells the ET8115C
Add a comment for more free help, for example a question about a specific model or about cross-over wiring. I have experience with wiring diagrams and experience with some different models.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 11, 2011 | Paragon Vintage 24 Hour Timer Command 12...
I need a replacement mechanism for a Paragon 24 Hr timer control Model 4004-71M.
1) Paragon is no longer making timers and parts except defrost timers.
4004-71M is not defrost timer.
2) Manual shows 4004-71M is DPST 40 amp 240Volt timer.
4000 series is 24 hour repeat timer
3) To buy replacement timer, Intermatic crossover guide shows T104M used for pool and spa controls and to replace timer mechanism
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
T104M at amazon
http://www.amazon.com/Intermatic-T104M-Mechanical-Mechanism-208-277/dp/B001DNYMV6
4) Or you can buy T104 with Nema1 indoor box, or T104R with Nema3R outdoor box
Googel search model number for vendor
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
5) How to wire T-104
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
For a price, fixya expert speaks with you over phone while you work on timer or any
Jan 07, 2011 | Paragon Vintage 24 Hour Timer Command 12...
I have intermatic t104 time 24 hour, the door hinges are broken can i get new door.
Page below shows Intermatic boxes, but doesn't describe which timer fits which box.
And the box costs as much or more than new timer.
http://www.electricsupplyonline.com/prod/intermatic-timer_accessories.php
Amazon sells T104 indoor
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/B000BQOX88/ref=pd_cp_hi_3_img
T104R raintight sold at Aplus
http://www.aplussupply.com/intermatic/timer.htm
Jan 05, 2011 | Intermatic T104 24h 208-277v Mechanical...
My lighting timer seemed to have burnt out. We thought that the switch was bad, because light was out - replacement one does not work either.
If I understand correctly you installed a new timer and it does not work.
You posted under EJ351 timer.
Problem sounds like it's electrical instead of timer.
1) Check electricity at wall box where timer is located. Remove both wires from timer. Separate wires for testing. Turn on power. Test each wire to bare ground wire. If box has power, then one wire will light up tester. This is Hot wire. Next test Hot wire to white wires inside box to make sure circuit can be completed to the neutral. If box doesn't have Not or Neutral then check other local boxes on same breaker to find where loose wire is.
2) Check that Load (light, fan, motor) is not burned out ... you can do this by putting regular light switch in place of timer. Box must test positive for Hot and Neutral wire.
3) Check that breaker is delivering 120V. Test from screw on breaker to any bare copper wire inside breaker box. Tighten screw on breaker. There is a white wire associated with black wire on breaker ... track this wire over to neutral busbar and make sure it is tight.
4) If electricity checks out, then timer is suspect. You may have gotten bad timer.
Nov 26, 2010 | Intermatic Programmable 24 Wall Switch...
The clock does not move forward. If I manually turn it, then it will work and turn on the system where the pins are. I haven't tried anything to fix it because I don't know where to start. Intermactic...
Sprinkler and irrigation timers are 14 day.
Intermatic has a page with manuals:
Open page, click plus next to timers and scroll down to sprinkler and irrigation timers
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
It's good to have the manual on hand in case the product is discontinued
That being said, it sounds like the clock motor is bad.
Snap timer free from box and tip out to see clock motor located on back of timer.
Get the number off clock motor
Intermatic site shows pages of clock motors: They are priced high, but cheaper than new timer.
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Aplus supply sells assortment of Intermatic clock motors.
http://www.aplussupply.com/intermatic/timermotors.htm
To search these pages quickly for your clock numbers, use browser Find (Click edit at top of bowser, click Find)
Nov 08, 2010 | Intermatic R8806P101C -...
My model t12404r will not turn the pump off. Even if I manually move the switch to the off position, the pump keeps running. The only way to stop the pump is at the breaker box. The other timer in the...
I don't know if you have a 240V pump and 120V cleaner.
Or if both are 120V
T10000 series manual has troubleshooting
http://www.polytecpools.com/images/pdf/intermatic_t10000r.pdf
I specialize in timers.
If the manual override will not work and the circuit cannot be stopped by the timer:
Then the timer is bad.
To check for sure:
When pool pump is OFF, use tester and check voltage across terminals 1 and 2 on pump side
When cleaner is OFF, use tester and check voltage across terminals 1 and 2 on cleaner side
What test results show:
The cleaner side test across 1 and 2 should show no voltage when timer is OFF
The pump side test across 1 and 2 should also show no voltage when timer is OFF
If the pump side test across 1 and 2 shows voltage all the time, then the timer is broken.
There are no replacement parts for the internal on-off mechanism.
Polytec pools and spas sells the same timer for $215:
http://www.polytecpools.com/intermatic-t12404r-control-center-w220v-dual-timer-wo-breakers-p-543.html
BH electric shows the T10000 series for $178
http://www.beverlyhillselectric.com/t12404r.html
Add a comment if you need help wiring your new timer
You have what is called a 2-channel timer.
A single-channel timer can operate 2 or more Loads (pump, cleaner), but the Loads turn on-and-off at the same time.
A 2-channel timer has a clock (or digital program in the case of digital timers) so each Load turns on-and-off with a different schedule.
As a general rule, 2-channel timers are more expensive.
To avoid the higher price, you can replace a two channel timer with 2 ordinary timers.
Let me offer a replacement strategy that might save you money.
Keep the existing timer for the cleaner.
a) Buy Intermatic T-104R weatherproof timer if you have 240V pool pump.
b) Buy Intermatic T-101R weatherproof timer if you have 120V pool pump.
Here is a resource for the Intermatic timer I am suggesting:
The webpage has links to sellers, it has manuals and it has wiring diagrams for the do-it-yourself-er
Nov 04, 2010 | Intermatic Timer T12404R Pool & Spa...
I added songs to my mp3 player and now it's frozen. It worked before I added the new music. It turns on but it won't do anything else including turn off. I changed the battery but that didn't...
Could be that one of the tracks you have loaded is copy protected (DRM) some players just skip these tracks, some show a "File format not supported" error, and others freeze.
Go to the folder where you store the tracks you have loaded on to the player using My Computer or Windows Explorer, so that the individual tracks show.
Click on the Views icon and select Details
In the right hand windows, right click on one of the headings which have just appeared, and put a tick in the "Protected" box.
"Protected" will now appear as a heading and each file will show Yes or No.
Any files showing as Yes are not compatible with your player.
If you are downloading these files from the internet, then you'll have to look elsewhere for files.
If you are ripping your own CDs to .MP3 or .WMA with Windows Media Player, then you need to change a setting in Windows Media Player.
Open Windows Media Player. If visible, click on "Tools" then options. If the menus are not visible, right-click at the top of the Media Player Window, then select "Tools" and click options.
Click on the "Rip CD" or "Rip Music" tab (depending on version).
Remove the tick from the box next to "Copy Protect Music" (or similar)
This will stop DRM protection on any further tracks ripped.
You will need to rip any DRM tracks again.
Apr 30, 2008 | Audio Players & Recorders
RCA,RP9328A,Audio System
I did the following to set the clock:
1. Press the Timer/Clock button until "CLOCK" shows, blinking, on the display.
2. Press Set/Demo. The hour indicator on the clock should start blinking.
3. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
set the hour.
4. Press Set/Demo. The minute indicator on the clock should start blinking.
5. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
set the minute.
6. Press Set/Demo twice. (Pressing once moves to the timer set mode.)
Feb 09, 2008 | Audio Players & Recorders
Bowflex Treadclimber Logo
1,603 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
