Bushnell Yardage Pro Scout Rangefinder
Problem for Bushnell Yardage Pro Scout Rangefinder
Magellen Meridian Color
By Kim1 - usenet poster
I am curious to hear from the Meridian Color owners what are the things that
you like and the pitfalls of this unit.
Best Solution
posted on Aug 02, 2007
Helpful)
Riddle
Rank: Apprentice
Rating: 0%, 0 votes
Hello!
You're taking waypoints during movement? Then the 2 second delay won't
be the problem...
Practice, practice, practice,...
Stefan
Motorrad :: GPS :: Reisen :: #
Was this helpful?
Yes
No
Solution #2
Not Rated)
Putty
Rank: Apprentice
Rating: 0%, 0 votes
It has that, too. :)
Try:
Menu
-Skramblr
Was this helpful?
Yes
No
Solution #3
Not Rated)
LiZzIe
Rank: Apprentice
Rating: 0%, 0 votes
Well I guess it's just an other "ho hum" boring unit all anyone can comment
on is the backlight.
Sounds like Magellan wants it on because it has the same problems as other
color displaces poor visibility if it is not in direct sunlight.
Was this helpful?
Yes
No
Solution #4
Not Rated)
M0nica L
Rank: Apprentice
Rating: 0%, 0 votes
I began to realize this last night when I was out in the dark and I
wanted a "Stay the hell on" mode.
Was this helpful?
Yes
No
Solution #5
Not Rated)
lawyer
Rank: Apprentice
Rating: 0%, 0 votes
The Color does have a 'stay the hell off' mode :)
Press power button - unit turns on with bright backlight.
Press and hold power button while it's on, it dims to low backlight mode.
Press and hold power button again, it turns off the backlight.
Press and hold power button again, it goes back to bright backlight.
Note - this is the opposite of how the monochrome units work. They start
with no backlight, then got to dim backlight and then bright backlight.
-Skramblr
Was this helpful?
Yes
No
Solution #6
Not Rated)
Beresford
Rank: Apprentice
Rating: 0%, 0 votes
Well, I got the Meridian Color about 10 days ago. My applications may
not be similar to he-who-bikes, but here goes --
I Bought the Meridian Color from Amazon.com for$395, along with a
Bushnell Yardage Pro Scout Range finder. The transaction was pleasant
and effective. Magellan is offering a $50 rebate, which I printed from
the Amazon web site, and have submitted.
I have had a Magellan GPS 315 for quite a while, since the 12-channel
units came out at reasonable prices and edged out the old guard (5 or 6
years?) and, of course, I was very used to it. I used it in airliners,
on car dashboards, left it strapped to a pole on the roof for a week,
and I've taken it to 3 continents and many islands here in the Pacific,
and it's stood the test of time.
The two primary reasons that I wanted a new GPS are:
1) WAAS
2) an external antenna.
I was looking at the Garmin GPS V for this, and discovering that the
Meridian Color would take an external antenna distracted me.
The Meridian Color provides both. I bought a Titan III active antenna
from the GPS Store.
Putting it side by side with my nasty old GPS 315, the Meridian seems to
be a lot more sensitive (using the built-in antenna) and of course goes
from power-off to nav solution in a shorter time (usually). When WAAS
kicks in, the error deviations cinch down pretty quickly compared to the
GPS 315. And the Meridian Color does, of course, have color maps, which
will be nice if I'm ever looking for something that I don't already know
where is, but in day to day life, a GPS unit is just an NMEA pump to me.
Mostly I use it with a Handspring Visor and Cetus GPS, since I do not
know of any GPS unit that records HDOP as part of a fix.
I'm impressed and happy with my purchase.
Still:
The user interface is annoying. This isn't a really big deal, and making
a fix requires holding a the GOTO button down for about 2 seconds, and
then pressing the ENTER button. The delayed reaction is a problem
because you have to start holding the button down prior to reaching the
place where you want the fix, and then you have to reach across to the
other side of the unit to finish the fix, which creates a little bit of
instability when using one hand. The old way, on the GPS 315 was to hit
the same button twice (click,click) and it took the fix on the first
click. I would rather have the old way.
Also, the back light doesn't have a "stay the hell off" mode, which it
needs. The display has good readability in sunlight without the
backlight, so it would be very good to extend battery life by forcing
the light to stay off when you didn't want it. Plus, there's this
annoying feature that the first button press activates the light and
doesn't do what the button was supposed to do, so you have to push it
again. This keeps confusing me in the field.
Still, even with the backlight tribulations, the battery life seems to
be relatively good. I just started using NiMHs in it, and they've held
up pretty well, even though a fully charged NiMH cell has a lower
voltage than alkaline, and doesn't make the battery meter go full scale.
It also doesn't display the time that a fix was recorded, I notice,
which can be useful sometimes.
I also wish it would stand up, like the GPS 315.
The base map seems to be accurate (which isn't a given in Hawaii), and I
will probably try the Mapsend software sometime soon, I have a friend
who can show it to me before I buy it. I haven't bought any SD cards for
it, but they're relatively cheap at Costco ($49 for 128 MB) so what the
heck. As I understand it, the SD card is necessary to put MapSend Maps
into the unit.
Was this helpful?
Yes
No
Popular Solutions for Bushnell Yardage Pro Scout
Questions and Unsolved Problems for Bushnell Yardage Pro Scout
Do you recommend Bushnell Yardage Pro Scout Rangefinder?
Answer
Answer
mine is a yardage pro scout and it eats batteries for breakfast. i can put a fresh battery the day... (More)
Answer
eroor e31 on the screen?Started after battery change
Answer
no lcd on bushnell yardage pro. Checked battery and can't get power button to respond....
Answer
why does my rangefinder battery go down after 1 or 2 times of use ?
Answer
I have the B.Y.P scout 700 yard. The liquid crystal displays the "scan" and battery emblem... (More)
Describe your Rangefinders problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Rangefinder Experts
Top Camera & Camcorder Repairmen
in Newport, KY
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
