Question about Toshiba 32HL67 32 in. LCD Television
Hdtv-dlp has no sound or picture
My tv hdtv-dlp has no sound or picture. When I turn the tv on the lamp light comes on and flashes for about 45 seconds to 1 minute then the lamp light shuts off but there is no picture or sound on the tv. I can access the menu, change the channels, and lower and raise the volume. but when I go to the tv/video button, when I try to scroll down from attenna it will not move. I have my dvd hooked up to video 1 connection but it is not recognizing it. The tv also will not turn off by the power button, I have to unplug the tv for the power to shut off. If anyone has any solutions it would be greatly appreciated. Thanks so very much. yes i have the same problem when i turn the tv on the lamp ligth tunrs on then all 3 ligths turn on at the same time but the tv never turns on can you help me? Same exact problem as rmilligan... turn it on, blue black screen than to strait black with a popping sound coming out of the speakers... i than unplug to turn off. Toshiba Regza 32''
  • two_saucy Mar 10, 2009
    Do you think it would possibly fix the problem if I bought a new power supply unit PE0246 V28A00030801 from eBay?
  • 39 Answers
This sounds like a dmd board problem. these are digital modules attached to the light engines usually. samsung, rca, hitachi, have shown similiar symptoms. some units have capacitors on the boards that can be replaced, but these are dual-layer pcb's that are tough to unsolder without proper soldering iron temperature and good small gauge solder-wick. or solder pump tool. the electolytic caps. are usually 1000uf / 10v, 330uf / 10v, or 470uf / 10v. alot of the time the capacitors will "vent" or swell-up on top which helps spot faulty component. we always increase voltage rating to 16v-25v for more reliable operation. always use 105 degrees high- temperature replacement caps.
Posted on Mar 09, 2009
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
Powers off with a blinking standby light for 45 blinks
Yes, its clear symptoms of weak lamp that is going to end of its working life, soon tv will show you lamp light.
Replace lamp to solve the issue, lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
May 25, 2010 | Sony KDFE50A10 50" HDTV
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Sony Grand Wega 55" LCD ml # KDF-55WF655 goes protective shutdown
This is the lamp going bad. For some reason, it doesn't spit out that lamp error, it just keeps refiring the lamp and it just cycles forever. When the lamp totally fails, you will get the lamp led lit. Replace the lamp to resolve.
Dec 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Black screen with a Blinking lamp in the front
Hi..if your lamp is on but no picture, then your lamp is good. Your problem is the DMD board (digital mirror display board) is bad. This is very common with Samsung DLP.
Mar 27, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Dlp tv will not "fire up"
if your tv is on warranty take it back to the supplier.the problem with your tv is in the power supply there is a open regulator in that circuit along with the H .O. Transistor there is a black that feeds from the HOT to the flyback which also needs to check probably it is also open.good luck my friend
May 06, 2007 | Samsung DLP HL-P5663W 56" TV
This sounds like an o-so familar problem. It sounds like the Switching IC or the MICOM has failed
Nov 10, 2006 | Samsung HLN467W 46" Rear Projection HDTV
Toshiba 32HL67 32 in. LCD Television Logo
540 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
