Question about Superstar SS-121 120-Channels Base CB Radio
Circuit diagram super star 121 c222 - Superstar SS-121 120-Channels Base CB Radio
How do i convert it to 11 meters
Posted on Mar 12, 2009
    Problem Solver:
  • 6 Answers
Try going to cb tricks.com
Posted on Mar 09, 2009
I Need a wiring diagram for 2006 F-350 Lariat Super Duty?
Wiring diagrams are by circuit. You need to be very specific as to what circuit you need.
Jul 01, 2014 | 2006 Ford F-250 Super Duty
Motorola SX600R circuit diagram
Sorry, schematics and part numbers for this line of radios were never released to repair centers.
Best regards.
Jan 22, 2013 | Motorola SX600R 14-Mile 22-Channel 121...
2009 chevy impala left front side deployment loop resistance B0014 above threshold
the following link covers yours reqest The driver frontal loops 1 and 2 are the loops to the steering wheel air bag. The SDM(sensing and diagnostic module for the air bag) is seeing these circuits as open. There is a bullitin for problems with a loose connection for the yellow connector behind the left kick panel(right behind the e brake and hood release). I would remove the kick panel, and disconnect and reconnect the connector a couple times. See if the light goes out. Or wiggle and move the connector with the key on, as the light should go out if it makes good connection. If it does go out you need to replace this connector. Good luck.
#05-09-41-001B: Supplemental Inflatable Restraint (SIR) Light ON, Diagnostic Trouble Codes (Inspect/Replace IP Harness to Inflatable Restraint Module (Air Bag) Yellow 4-Way Connector C221 and/or C222) - (Jun 2, 2008)
Subject:Supplemental Inflatable Restraint (SIR) Light ON, Diagnostic Trouble Codes (DTC) B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044 (Inspect and/or Replace IP Harness to Inflatable Restraint Module (Air Bag) Yellow 4-Way Connector C221 and/or C222)
Models:2003-2006 Cadillac Escalade Models
2003-2006 Chevrolet Avalanche, Suburban, Tahoe
2003-2007 Chevrolet Silverado (Classic Only)
2003-2006 GMC Yukon, Yukon XL, Yukon Denali, Yukon Denali XL
2003-2007 GMC Sierra (Classic Only)
This bulletin is being revised to add the 2007 model year for pickups and change a part number. Please discard Corporate Bulletin Number 05-09-41-001A (Section 09 -- Restraints).
<A href="#ss1-2146754">
Condition
Some customers may comment that the Service Supplemental Inflatable Restraint Light is on.
Diagnosis with a scan tool may indicate a DTC B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044.
<A href="#ss2-2146754">
Cause
The most likely cause of any one of the following DTCs: B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044 is improper connection/high resistance in the IP harness to inflatable restraint module connector C221 and/or C222.
<A href="#ss3-2146754">
Diagnostic Information
DTC B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044 will set when one of the following conditions occur:
• The SDM detects the air bag module deployment loop resistance is greater than 4.8 ohms for 500 milliseconds.
• The SDM detects that the voltage at the air bag module high control is less than 2.4 volts and deployment loop resistance is 6 ohms or greater for 500 milliseconds.
• For additional diagnostic information, refer to DTC B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044 in the appropriate SI Document.
<A href="#ss4-2146754">
Correction
DO THIS
Don't Do This
Test for proper connection/high resistance at connector C221 and/or C222.
DO NOT replace SIR system components prior to testing for proper connection/high resistance in C221 and/or for DTCs B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044.
Caution: When performing service on or near the SIR components or the SIR wiring, the SIR system must be disabled. Refer to SIR Disabling and Enabling Zones. Failure to observe the correct procedure could cause deployment of the SIR components, personal injury, or unnecessary SIR system repairs.
Important:
The IP harness to inflatable restraint module connectors C221 or C222 is NOT located at the base of the steering column.
• C221 (4 Cavities) -- I/P Harness to Body Harness, behind the left kick panel
• C222 (4 Cavities) (w/o HP2) -- I/P harness to body harness, behind the right kick panel
• C222 (4 Cavities) (w/HP2) -- Behind the left side I/P access panel
• Refer to the Master Electrical Component List for additional location information.
  • <LI type=1>Remove the appropriate side door sill plate. <LI type=1>Remove the appropriate side hinge pillar panel. <LI type=1>Locate the IP harness to inflatable restraint module yellow 4-way connector C221 or C222. <LI type=1>Inspect the IP harness to inflatable restraint module connector C221 or C222 for proper connection. <LI type=1>Disconnect and reconnect the IP harness to inflatable restraint module connector C221 or C222 THREE times. <LI type=1>Clear the DTC and road test the vehicle. • If DTCs B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044 DOES NOT reset, no additional repairs are necessary. Continue with step 10.
    • If DTCs B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044 DOES reset, the most likely cause is high resistance in the IP harness to inflatable restraint module connector C221 or C222. Continue with the next step.
    <LI type=1>Replace the appropriate connector C221 and/or C222, P/N's 15306186 and 88987998. Refer to SIR/SRS Wiring Repairs (SI Document ID #325229). <LI type=1>Road test the vehicle and confirm that the repair is complete. <LI type=1>Install the driver's side hinge pillar panel.
  • Install the driver's side door sill plate.
<A href="#ss5-2146754">
Parts Information
Part Number
Description
Qty
15306186
Connector (4-way Female, w/Leads)
Connector (4-way Male, w/Leads)
1 Service Airbag Have Codes Ask the GM Technician
May 01, 2012 | Chevrolet Impala Cars & Trucks
How to use the Hard Disk for Super MB STAR, anything i can do to learn
Hard Disk for Super MB STAR 2011.09 External HDD Format
Hard Disk for Super MB STAR 2011.09 external HDD Format is software for Super MB STAR, software version 2011.09. It works together with Super MB Star. It can used on computer with windows xp computer. Your computer need have serial port.. It is only one hard disk and it is DELL D630 format, so it can used on computer with windows xp computer. Your computer need have serial port.
2. It works together with super mb star and it has usb key in the package.
3. Software version is 2011.09. Update on www.supermbstar.com
Package including:
1pc x Mobile HDD with USB Cable
1pc x USB KEY
1pc x Verification Letter with Password inside
Contact information:
Skype : greebid6
UOBD2.COM
MSN: chinauobd2@gmail.com
sales@uobd2.com
E-mail: chinauobd2@gmail.com If any problems,pls feel free to contact us.
How to purchase on UOBD2.COM?
hope it helps
Apr 20, 2012 | Computers & Internet
How do i increase the power in my super star 121 radio?
To increase modulation you want to change R142 and R174 to 10 K Ohms. You
Modulation boost: Change R142 and R174 to 10k ohms.You can clip d80 for talkback. Now for the power, look in the radio towards the back. You see the pot with the ferrite in it right behind c144 - it might have some glue in it. Gently scrape that glue out of there with a plastic screwdriver. Now unscrew that ferrite clear out. Those will be your main adjustments you can do without a scope.
Jan 26, 2011 | Superstar Radio Communications
CODE B0026 HOW DO I RESOLVE? REAR DOOR LOCKS NOT WORKING, SERVICE BRAKE BOOSTER WARNING ON, AIRBAG LIGHT ON, SERVICE AIRBAG WIRNING, INTERMIT NO START. HELP MEEEE!!!!!!
The airbag connectors in behind the front kick panels have high resistance. The fix is to replace them. Here is TSB's
Subject:
Models:
Condition
Cause
Correction
DO THIS
Don't Do This
Important: The IP harness to inflatable restraint module connectors C221 or C222 is NOT located at the base of the steering column...
1. Remove the appropriate side door sill plate.
2. Remove the appropriate side hinge pillar panel.
3. Locate the IP harness to inflatable restraint module yellow 4-way connector C221 or C222.
4. Inspect the IP harness to inflatable restraint module connector C221 or C222 for proper connection.
5. Disconnect and reconnect the IP harness to inflatable restraint module connector C221 or C222 THREE times.
6. Clear the DTC and road test the vehicle.
7. Replace the appropriate connector C221 and/or C222, P/N's 15306186 and 88987998. Refer to SIR/SRS Wiring Repairs (SI Document ID #325229).
8. Road test the vehicle and confirm that the repair is complete.
9. Install the driver's side hinge pillar panel.
10. Install the driver's side door sill plate.
Parts Information
Part Number: 15306186
Description: Connector (4-way Female, w/Leads) - Qty 1
Part Number: 88987998
Description: Connector (4-way Male, w/Leads) - Qty 1
Hope this help (remember comment and rated this help).
May 07, 2010 | 2003 Chevrolet Suburban 1500
P0123, p0121
123 throttle position sensor/switch A circuit high input 121 throttle position sensor/switch A circuit range/performance problem if running fine try reset--- if running rough black smoke star problems check the TPS wiring ,connections,and mounting if looks good not grounding ,rubbing or damage to wiring than test TPS sensor
May 05, 2010 | 2002 Jeep Liberty
How do i get more mod out of superstar 121 cb
A super star will only put out around 28 to 30 watts, any more you need a linear, you could have you r swr checked to make sure your antenna is good, any good antenna should talk around 10 miles
Nov 22, 2009 | Superstar SS-121 120-Channels Base CB...
I want to know how to convert my superstar121
3 Bands (LOW - MID - HIGH) 25.515 - 27.855 MHz.
Export Frequency Conversion
1. Remove the top cover from the unit and locate the PLL chip (MC145106P). Unsolder the short jumper wire running from the +8.2vdc source to pin 9 of the PLL chip. 2. 2. Resolder the three pins of the PLL chip, Pins 10, 11, and 12, being carefull not to short them together. Note: The Super Star 140 Microphone wiring is the same as all Midland Radios.
Mar 12, 2009 | Superstar SS-121 120-Channels Base CB...
Radio Communications Logo
437 people viewed this question
Top Superstar Radio Communications Experts
AnyMHz.com
AnyMHz.com
yobo007
yobo007
cwradio73
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
