Question about Foxconn 661M03-G-6EL Motherboard
MB Foxconn 661M03-G (s. 478) problems with IDE/ATAPI controllers
Hi there, I want to ask you for help guys :)
I have 2 HDDs, and both are working in UDMA2 (Ultra ATA 33) mode. The speed of system is very slow - it should have work in UDMA5 (Ultra ATA 100/133) mode, but it is not. I do not have an installation CD, so I can not install IDE drivers. Can someone help me please?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 59 Answers
Hello uxmal,
The Drivers of 661M03-G
On-Board VGA Drivers: Click Here
AGP Drivers: Click Here
On-Board Audio Drivers: Click Here
BIOS File: Click Here
Thank you for using FixYa.
Posted on Apr 09, 2009
My new 500Gb SATA HDD hasn't work on 600A01-6LRS motherboard. Updating BIOS to a version from 3/23/05 didn't solve the problem. What should I do?
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Nov 30, 2010 | Foxconn MB KT600 600A01-6LRS Motherboard
I have an old desktop pc, ASUS P4S533MX, Intel socket 478, with SiS PCI IDE Controller.. ( IDE ATA/ATAPI ) 1. Can I upgrade the Radeon 9250, 128 Mb DDR 64-bit to something better? 2. Is it...
well...ASUS P4S533MX- Intel socket 478 allow maximum processor upgrade from 3.2 GHz upto to 4.2 GHz.
for upgrade the Radeon 9250, 128 Mb DDR 64-bit ....whole moherboard along with new processor has to be replaced. an expensive deal..
better to buy new motherboard+compatible processor of ur choicce
Sep 19, 2010 | Intel ASUS P4SC Socket 478 Pentium 4...
Intel DG31PR, How many HHDs can i add?
The board has 4 SATA ports and one IDE port. Therefore, assuming that you also want to connect a CD/DVD drive, you should be able to add another two SATA HDDs. You may need to get a SATA power adapter (splitter) cable, if no no more unused SATA power cables are available.
Also make sure that your power supply is not already "at the limit"...
Mar 22, 2010 | Intel DG31PR Motherboard
IDE Connection to HDDs Problem
Check the IDE cable, Jumpers (Master/slave), power connector/cables, this will fix your problem if there's no internal damage on the motherboard. Good luck Thanks for using FixYa.
Jan 20, 2009 | MSI K9VGM-V Motherboard
Problem ide
Hi gustabir,
try this first. (If I am understanding you correctly).
Power on the PC, press the Delete key every two seconds untill the boot menu loads. Go to the title, Boot. Set you're boot device's in the correct order. They should be listed as follows.
1st Boot device Floppy drive. (If a floppy drive is connected).
2nd Boot device CD-ROM/DVD drive.
3rd Boot device Hard drive.
(If you're CD-ROM drive is not listed in the bios main menu, than you're CD-ROM drive is not connected correctly). Please check the CD-ROM data cable is firmly & correctly connected), also check the power cable is firmly connected). If you are using more than one CD/DVD-ROM drive on the same data cable, check that you are listing the correct CD/DVD drive in the boot order. To change the drive's order while in the Boot menu, see page 34 in you're manual.
If the above does not address you're problem, please describe the issue/problem again.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Speakers Not working
Kristy,
  • Can you find the manufacturer name for your audio? if yes then goto the manufacturer's site and see any link like support/downloads..etc. And make a downlaod for your model.
  • Other wise goto your motherboard manufacturer's site, see specification for your model and try to findout the manufacturer's names for audio embeded on your motherboard. The audio driver for your might be avail at the motherboard manufacturer's site.
If still have problem just Ask me....
Thanks
Iqbal
Apr 26, 2008 | Intel Motherboard
Foxconn Utility CD for motherboard Intel 915 series p/n: 91-185-915-MB-OM W A N T E D
Hi Witalorant,
I have searched the driver for your motherboard chipset and found one similar for the one you were looking at, i copy and paste the link here for you to download it and install it to your unit.
Click the link below and see what driver you need to download when the page loaded..
INTEL 915
Hope it helps.
Enjoy
Pls. rate & hope to hear more from you soon..
tnx
-micro
Feb 10, 2008 | Foxconn 915P7AC-8KS Motherboard
SATA Disk Problem
Is it a SATA II drive?
If so, you need to jumper the drive to "downgrade" to SATA I before the Via controller will recognise it.
WD5000AAKS needs to jump 5+6. I don't know about other drives, but I'm sure you can find it.
I hope I've made your day, just as this info did to me when I found it!
Nov 02, 2007 | Foxconn MB KT600 600A01-6LRS Motherboard
Secondary IDE not working
Try to check if there are some capacitor has been damage. Replace the capacitor in each specific specification. You can do it yourself by using soldering iron.
Hope this is helpful to you.
Please vote me if I'm done correct solution.
Oct 30, 2007 | ASUS A8V-VM Motherboard
P4M9007MB Motherboard
Yes, VIA VT8237A (stay as south bridge on your mobo) support ATA133. You can use upto two IDE/ATAPI devices.
Sep 27, 2007 | Foxconn P4M9007MB-8RS2H Motherboard
Foxconn 661M03-G-6EL Motherboard Logo
537 people viewed this question
Top Foxconn Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
