Question about JVC DRMH50 DVD Recorder
I have an JVC DRMH50 and it has ceased to operate the hard disk. has ceased to read and write. My question is: how to change a computer's hard drive with similar features or need any special software factory to initialize the new disk.
    Problem Solver:
  • 7 Answers
Apparently you need special software for the hard drive. I had problems with mine and the power supply eventually gave up and I had to replace it from JVC. Looks like it is a common problem.
Posted on Nov 19, 2009
I have a JVC GZ_MG20U hard disk camcorder. I need to know where I can download the drivers to my computer so I can down load my pictures and video. The JVC web site stoped suppling free drivers for reasons...
You should be able to see this camcorder as a drive (a disk) when you connect it to your computer.
Depending on the number of drives you have on your machine, it may show up as drive E:, assuming you only have a C: and a D: drives.
Or it may be F:, G:, H:, etc.
Using your Windows Explorer (NOT Internet Explorer), you can navigate to this drive, and copy or delete any video files on the camcorder to whatever location you want on your computer's hard disk.
As far as I know, you shouldn't need any drivers for this.
Simply connect it to your USB port, and give it minute or so until Windows recognizes it, and, if necessary, until it installs USB drivers for it. Just keep an eye at the system tray (bottom right of the screen)
Dec 24, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I wanted to wipe my entire hard drive on my old Dimension 8400 that contained windows xp on it and reinstall it with windows vista, which i have the cd for. however, when i did so, each time i try loading...
1. you will need to know 1st that the hard drive you are installing is compatible with the desktop.
2. Is the hard drive compatible with the new Operating system (VISTA).
3. Check to see if you have the hard drive properly inserted that is properly cabled and connected.This will render error in installation.
4. Make sure you are installing the Operating system correctly.
5. Some boot sectors become corrupt during a change in Operating system if the hard drive is not properly formatted.
6. Try formatting the hard drive again and re-installing.
Feb 12, 2011 | Dell Dimension 8400 PC Desktop
Computer has become very very slow. Reformated and reloaded operating system took forevery to reload (2 hours). Is this a hard disk problem
It _could_ be a disk-drive problem -- excessive "retry" operations within the disk-drive, while trying to write data to the disk-drive, or while trying to read from the disk-drive.
Search online for "Hitachi Drive Fitness" testing software, and run it.
If the disk-drive is "out-of-warranty", consider replacing it, before it completely "fails".
Nov 11, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
I have a jvc SR-DVM70 - The hard drive is about 75% full of data so I don't want to lose that. The deck was working fine recording through the firewire to the hd. Problem was it didn't playback through the...
The hard disk hasn't been recognized in Windows because the JVC runs Linux so the drive was formatted in EXT3 which Windows can't read.
Simple fix to recover all your data: connect the disk back to the pc and boot from a Linux Live-CD like
http://pclinuxos.com/
In there all you have to do is to copy all the content of the disk to your local disk (PCLinuxOS can read and write securely on NTFS/Windows disks). Or you could just burn them to some dvd's.
For the rest: 1 - on the CS pins; 2 - no.
Jun 25, 2010 | JVC SR-DVM70 DVD Recorder
Does not read on computer
Could you plz specify the brand of your HD?
which operating system do u have?
go to diskmanagement and assign any letter to your HD.
or u can change the hardisk kit and then see if it works.
Jun 08, 2010 | SmartDisk (DHXF250F) 250 GB Hard Drive
Operating System Not Found on VAIO Laptop
The disk-drive inside the computer has ceased to function (or has ceased to have connected "power" and "data" connections) -- thus, the Operating System cannot be read from the disk-drive.
Take the computer to a qualified technician; there's nothing that you can do "inside" your computer.
Jan 20, 2010 | Sony VAIO VGN-AR150G Notebook
The computer reads the hard drive but i dont see a disk drive on' my computer' i.e i cant access the hard drive.
Do the following to see if the hard drive is recognized.
Left Click on control panel
Left Click on administrative tools
Left Click on Computer Management
scroll down the screen until you find disk management
left click on disk management.
see if you device is listed in the disk management window.
If so then, right click on the disk you indicated and select properties.
make sure the disk is active and that windows is reading the basic information.
IF your computer does not recognize the hard disk, you may want to disconnect it and reboot your computer.
then reconnect it, and restart once again.
this allows your bios and operating system the chance to "discover" your hardware again.
pls rate 4 stars
Nov 29, 2009 | Western Digital (WD1200BEVS) 120 GB SATA...
"Error loading operating system" message
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
Apr 09, 2009 | Sony VAIO VGN-FE660G Notebook
If i turn dvd on it says LOADING and keeps flikkering
try to format your hard disc or to reinstall the operating system
Mar 24, 2009 | JVC DRMH50 DVD Recorder
No bootable devices
go to BIOS MENU by pressing Del or F2 while booting...then check the boot priority and first boot device..change it to hard disk...if then same problem occur then your hard disk might have some problem...
Jan 23, 2009 | Dell Inspiron 2200 Notebook
JVC DRMH50 DVD Recorder Logo
197 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
