Question about RCA P52929 52" Rear Projection Television
Remote Sensor We were given an RCA P52929 from a family friend. Were do we find the remote sensor?
  • 60 Answers
Its s usually to the right or left of all the buttons (channel, volume, menu, etc) it might have a tinted plastic small square covering it, i take it your trying to program a universal remote
Posted on Mar 08, 2009
Why wont a universal remote or regular remote work to my rca television
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
If remote control is working OK, the fault should be with the infrared sensor inside the TV. Contact any service technician to replace it. If you're trying to use a universal remote control, it should be synchronized with the TV, with set-up code said for TV. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 21, 2014 | RCA Televison & Video
The remote sensor in the TV unit is not responding
Check the remote control for its infrared emission first. If it found OK, check and replace the remote sensor inside the TV. To get more details, http://electronicshelponline.blogspot.com/ Testing procedure to remote control is given in detail. 5861f1e7-87a3-433c-a8c7-016dc4787f6c.jpgec36d179-61eb-46d0-b8d0-578cf88fc7b0.jpg
Remote sensor will look like this.
Nov 17, 2013 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Brighthouse remote
some remote control they have not incorporated from old device. Will be a good idea to replace it. Of course you must sure the sensor from the old device is working.
God bless you
Jun 22, 2013 | RCA Televison & Video
Remote sensor board rca tv model p52928
Disconnect the board if you have a real working remote, set will work via the remote without that board---remote sensor is behind screen and above the board.
Nov 28, 2012 | RCA P52928 52" Rear Projection Television
My remote wont work rca 40 inch lcd
Check the remote by looking through a digital camera at the remotes light while pressing the remote buttons if you see the light then the remotes working and you most likely need to replace the IR sensor. You can get the remote and the IR sensor from www.tvrepairworld.com
Nov 09, 2012 | RCA Televison & Video
Vcr sensor not responding to remote
Hello
If you are sure that the remote control works well, and VCR does not respond to it [you haven't here given any details about uour VCR; its Brand name, Model number etc:-], the remote sensor of your VCR is faulty. You can replace it, if you have an idea and knoledge in electronics. You have to disassemble the front panel of the VCR, to locate this device. It will come just behind the infrared window, will look somewhat bronish black in colour, a three terminal component.
gopakumarg43_89.jpggopakumarg43_90.jpg I hereby includes the picture of a typical infrared remote sensor, and its typical circuit dagram, to know you the pin numbers. Just try, if you are familier with electronic equipment service. If you are not skilled to do this work, get this set repaired by any experinced service technican. OK.
Oct 13, 2011 | RCA Televison & Video
Picture is warped. rca 52 inch model p52929
This is hte beginning of a convergence problem. If you can solder, try resoldering the pins on the convergence ICs. These are large black ICs attached to a heat sink and will be marked STKxxx. If that fails to resolve the problem, replace the ICs.
Keep us posted.
Dan
Aug 25, 2008 | RCA P52929 52" Rear Projection Television
RCA P52929
go to the menu select the screen option 3 and then select option 6 . adjust projection tv. green is for green use it first then adjust the red and blue until the patterns on the tv screeen appear white.
Sep 26, 2006 | RCA P52929 52" Rear Projection Television
Remote sensor in the TV
First Inspect the remote batteries. also make sure TV is not on a LOCK ON option... now, the sensor is a small smoothly part near the TV front buttons, you can clean it carefully FYI, exposing unit remote sensor to direct fluorescent or outdoor light may cause signal interference.
Nov 14, 2005 | RCA P46924 46" Rear Projection Television
RCA P52929 52" Rear Projection Television Logo
87 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
