Question about HP Pavilion ze4200 Notebook
My hp pavilion 4200 i took the hard drive out and put it back in when i booted it up it says media cable not found then it says operating system not found. tried to run the operating system cd and it says hard drive not found. what is my problem
  • HP Master
  • 32,281 Answers
The laptop can't find a hard disk, eirher the hard drive is faulty or not seated properly.
Take out the hard drive and reseat it again then see if the laptop boots up. If it still can't find the hard drive, listen to the hard drive, is it spinning up, is it making clicking noises? This indicates a faulty drive and needs to be replaced.
You can also test the hard drive by removing the hard drive and attaching it to a USB hard drive adapter and then plug it into a working computer's USB port. If the hard drive is OK then the computer will see it as an external drive and you can view and open the files.
Posted on Mar 08, 2009
Operating guide
is your hard-drive the boot-drive, if not, change boot order by pressing F8 or F12 just after hitting the start button, and choose the hard-drive that has the C:\windows on it.
or hit F11 and access hidden recovery partition with HP pavilion How to Access the Hidden Recovery Partition in HP Pavilion
Mar 23, 2014 | HP Pavilion Computers & Internet
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
Black screen says PXE-E61 Media test failure, check cable, Operating System not found. I hear wierd sounds from the computer.
Sounds like it could be a bad hard drive. With your laptop turned off, take out the hard drive and put it back in and make sure its nice and snug.
Then go ahead and turn on the laptop and see if you can boot back up into windows.
If you can't get into windows and you get the same message then boot up the laptop and go into the BIOS by pressing F2. When you get into the BIOS look and see if your BIOS is recognizing the hard drive, if it's not seeing the hard drive then that means your hard drive is bad and would need to be replaced.
If your hard drive is showing up then that means you have corrupt system files and you'll need to restore your laptop back to factory defaults with your recovery cd's.
May 23, 2009 | Toshiba Satellite M45-S169 Notebook
Bios shows not hard disk even after putting to Auto and trying User settings
This usually means Hard Drive failure, are your connections good? Is this a new drive? If you know you have a drive with os on it then boot files could be damaged. Can you boot with os disk? You can do a repair from the windows disk in recovery mode. reset bios to default values. Last resort before saying maybe the drive controllers on motherboard are bad. Take apart and do good cleaning. This worked believe it or not on a stubborn laptop that I replaced Hard Drive and still was giving me similar errors. Client says computer has been working ever since.
Char S.
May 21, 2009 | HP Compaq (319612-001) for Pavilion...
PXE-E61: media test failure check cable
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 18, 2009 | HP Pavilion dv1000 Notebook
Booting problems with acer laptop - no operating system found??
PXE (pronounce Pixie) is an agent used to boot on to the network.
It's using the DHCP protocol to localise a server where the image of the OS is located
If, for any reason, the hard drive is not seen the computer will attempt to boot on the network controller.
This can be caused if the hard drive is missing, unplugged or corrupt, or simply by not having the boot order configured correctly.
When you start your laptops, press F2 repeatedly until you enter the bios set up, navigate to the boot order and make sure that the hard drive (sometimes listed as HDD....) at the top of the list.
Hope this helps, let me know if you need anymore help.
Jan 27, 2009 | HP Pavilion dv6000z Notebook
Acer Aspire 5050 won't boot up
ooh...no operating system. not good. ok..can you boot from CD? if that works, and it asks you to reformat the hard drive, STOP. Take the hard drive out, and then GENTLY reinstall. Maybe that will work. HD's can fail on laptops, just by a series of vibrations or shocks to the case.
got backup for your Acer?
Feb 16, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion ze4200 Notebook Logo
337 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
