Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Too much oil on the chain
I seem to be going through an excessive amount of bar oil. Is this just because temps have warmed up? Am switching to the summer oil. Also 1 of the 2 chains it came with is now ratched 2nd chain is not far behind. The bar itself is looking worn. Was thinking of going with a 20" or 22" to replace any thoughts on that?
    Problem Solver:
  • 7 Answers
If you are using winter grade bar oil, then when the temps warm up, you are going to go through a lot more bar oil, because the winter grade is much more loose compared to the summer oil. I would not be to worried about using too much oil, because it just means that it is working and lubricating the saw well. About switching to a larger bar, I would not recommend going to a larger bar than what came with the saw, Unless the manufacture states what size bars can be used for the saw. Going to a 20" or 22" bar could bog down the machine, making cuts slower and not as clean, since the increased length of the bar would be too much for the motor to handle. with the larger bar the chain would be larger as well. So the power needed to move that chain has to be increased as well. So unless the manual says something like, "available bars lengths are..." Then I would just stick with the bar size it came with.
Posted on Mar 10, 2009
Excessive use of chain oil
Unlike most bigger gasoline powered chainsaws, the Ryobi RCS2040 electric chainsaw does not have an oil adjuster. The oil pump on it is pretty much a simple mechanism that moves the oil on a "cork screw" -it rotates when your chainsaw runs, then your oil glides out of the reservoir into the tube towards the chain oiler. Amount of oil used will depend on two factors: 1.) Type of oil used. We sell winter grade and summer grade (but we are in Southern California, this doesn't make any difference). Our customers prefer the less tackier ones because it doesn't burn their bars under heavy use and it is less strain on the unit, however this drips out fast. 2.) Integrity of your oil line system, and the size of your reservoir (on your model, it IS small). Our rule of thumb here is that if it drips bar & chain oil, it's working. Well, that is unless it's leaking someplace else other than the bar oiler. Check the oil tube - it should be on the bottom of your chainsaw right on the same side as the oil tank.
Generally, speaking for both mid-sized electric and gas powered saws - 45 minutes of worth of cutting should have your bar and oil tank depleted already. Our contractor customers even have it opened way up.
Jan 12, 2014 | Ryobi Garden
Poulan Pro 42cc 2-Cycle 18'' Gas Chain Saw excess oil on chain
are you using a chain bar oil as this is a lot thicker than normal engine oil
Jul 16, 2012 | Poulan PP4218AV 18" Chain Saw
I have a b and d alligator lopper that has never been used, but no manual. How is the chain lubricated? Type of oil? How is oil applied? Thx.
Information on your product, inlcuding a link to the Manual may be found here:
http://servicenet.blackanddecker.com/Products/Detail/LP1000
A high quality bar and chain oil or SAE30 weight motor oil should be used for chain and bar lubrication.
The use of a vegetable based bar and chain oil is recommended when pruning trees. Never use waste
oil or very thick oil. These may damage your chain saw.
- Before first use and every ten minutes of use you must oil the product with the recommended chain oil. Open the oiling cover and insert the bottle into the oil filling hole apply pressure to the bottle once to dispense oil.
- This should be adequate for about 10 minutes of cutting depending upon cutting speed and type of wood.
- The hole feeds the oil through to the chain onto the chain bar and an excessive amount of oil applied to the unit could mean the oil drips from the unit around the jaw area. This is normal and is nothing to be concerned about.
May 23, 2011 | Black & Decker Black Decker Lp1000...
Excessive bar oil coming from clutch area.
Is bar oil getting on the chain? Depending on the model, their maybe an adjustment on the oil pump to control the flow, check the owners manual. Also make sure you are using bar and chain oil as regular motor oil is much lighter and tends to get "flung" off more.
Feb 16, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a 365 special that is using an excessive amount of bar oil.
Not sure if this model has an oil volume adjustment--look for a screw head located near the chain return area on the back or underneath in the same area. Turn the screw CW to reduce volume. Run the saw at speed with the bar tip near some cardboard for several moments--it should throw off a thin line of oil. Hope this helps!
Aug 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 455 Rancher - oil coming out of muffler and not oiler. Just emptied gas and remixed new batch so that should not be issue. It was working fine until I took off chain cover to clean and got brake...
Re-clean the engine case and loose parts. Start the engine with the bar removed--oil should ooze out of the side port where the bar fits to, but nowhere else. Clean the bar drive end oil passages--especially the two small channels that go out to the chain groove on both sides. If you seem to be pumping excess oil out, there should be an oil volume adjustment screw either in the back case or just underneath the case near the lower run of chain. Turn the screw CW to lessen the volume of oil. Hope this helps!
Jun 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Good Morning : I have a Husqvarna 142 e chain saw about 2 years old and I have an excessive amount of bar oil dripping out . Is there some kind of flow adjustment for this problem ? Thanks , Mark :
First, deactivate the chain brake, back-off the chain adjuster, then remove the bar and chain. Run the engine at speed for a moment or two--the oil should ooze out of the engine side port. If the oil quantity seems about right, then clean the drive end of the bar oil-passages including the two small passages that go out to the chain groove on each side. Clean the chain groove and check the sprocket on the far end (if equipped). Reassemble the bar and chain, then start and run the engine at speed for several moments with the bar tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard. Check the owner's manual for location of any oil-volume adjustment if needed.
Jun 04, 2010 | Husqvarna Garden
Chain stops when contact is made with tree
I'm assuming that the engine continues to run, but the chain stops moving. Remove the bar and chain. If the clutch internals are full of bar oil and other debris, try washing out the clutch with spray carburetor cleaner from an auto parts store. After it dries, inspect the shoe faces and inner drum area for excessive burning or scoring. Apply a small amount of oil to the clutch hub bearing, then reassemble the bar and chain. If the chain now cuts correctly, you are home free. If it doesn't, then the clutch will need replacement. Hope this helps!
May 17, 2010 | Garden
I have a stihl 041 farmboss and I am getting excessive bar oiling on the chain and bar. I was wondering if there is an ajustment to control the amount of lubrication to the chain and bar. Thanks Jim
Yes, but the location of the oiler is a secret.
An entire thread dedicated to your question follows (see post 5):
http://www.arboristsite.com/showthread.php?t=33705&highlight=041+oiler+adjustment
Please go here and request a manual. Please ask they add one that can downloaded too.
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 12, 2010 | Garden
The chain became dislodged. When I put it back on it is loose and sags. How do I tighten the chain? Thanks
You didn't say what kind of saw you have but they are all generally alike. This happened because the chain stretches when it gets warmed up and it also gets a slight amount of wear in the pins so it lengthens as it is used. There should be 1 or 2 nuts on the side cover over the drive sprocket that you need to loosen just so the bar is loose and there should be a screw on the inside of the bar that faces the tip of the bar. When you turn this screw it will adjust the bar outward which will then tighten the chain up. Tighten the nut or nuts back up with upward pressure on the bar. It should be almost snug when cold. Make sure you have bar oil in the oil tank to lubricate the chain or it will soon stretch and come off again. This can ruin your chain and they aren't cheap
Aug 24, 2009 | Desa International Remington 14" Electric...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
258 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
