Question about Maytag MZD2766GES Side by Side Refrigerator
Refridgerator too warm freezer ok running constantly
  • 163 Answers
Could be your evaporator fan which is located in freezer.If you dont hear it blowing when compressor is running then it is evap. fan motor.if you see alot of frost building up on back panel inside freezer then you have a defrost problem.check heater and thermostat to see if they are good or bad.the thermostat will usually pop apart but not always it is located at the top in back of freezer on coils.it will have two wires going to it.good luck.and unplug first.
Posted on Mar 08, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
The refridgerator and freezer are failing to maintain temperatures. The light for the refridgerator temp. is blinking constantly. Both sides continue to raise in temp. regardless of where the setting is...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Samsung RS2630SH Side by Side Refrigerator
Refridgerator and Freezer
Compressor may be warm but not running. What part is brand new? Would you like me to assist you? If yes please make sure your model number is correct. I'm waiting for your reply, Sea Breeze
Nov 19, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Kenmore Freezer works, but refridgerator is warm
Either there is a refrigerant leakage or if it is a no frost refrigerator air ducts to the refrigerator is closed due to frosting. Switch off the refrigerator for 3 hours and restart again.
Aug 15, 2009 | Refrigerators
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Frig is warming while freezer is staying cold.
No, A compressor will get hot for about three reasons.
Low refridgerant.
Lack of airflow, (maybe due to very dirty coils or bad condensor coil fan on modes with a fan)
Or high amp draw. (which would mean you have a bad compressor)
Its more common to be one of the first two, especially low refridgerant.
Dec 05, 2008 | Refrigerators
Refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Oct 15, 2008 | GE GSS25JEMWW Side by Side
Amana 8 yr old side-by-side refridgerator/freezer
sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
Dec 04, 2007 | Amana AFD2535DES French Door Refrigerator
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
135 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
