Question about Apple iPhone Smartphone
When I access voicemail the iPhone crashes
When I try to tap on a voicemail, the iPhone screen goes immediately black. I can get it to come back by pressing the reset/power off button at the top right on the phone. It's NOT a problem with the infrared sensor - the screen doesn't come back on even after two minutes if I leave it completely alone and am nowhere near it unless I hit reset/power-off button on top right of iPhone.
  • Anonymous May 03, 2009
    Same problem - whenever I click on a voicemail to play it back, the phone screen immediately goes black as if I pressed the "sleep" button. I have to press the sleep button to turn it back on.
  • Apple Master
  • 4,338 Answers
Apple has released the 2.2 update which fixes alot of these crash issues. Update the iPhone it from here:
http://www.apple.com/iphone/softwareupdate/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 10, 2009
Recovering voicemails I accidently deleted
hi Tee.
To find your deleted voicemails, open the Phone app, tap Voicemail, and scroll down to the bottom of the page until you see the words "Deleted Messages". If you do not see the Deleted Messages panel, then there are no messages to recover.
Can I recover a deleted voicemail on my iPhone? ' The iPhone FAQ
or this link to help you out some more.
Recovering voicemails accidently deleted Google Search
Dec 02, 2017 | Cell Phones
What is bypass code
Tap the "Emergency Call" button, then enter three pound signs, hit the green Call button and immediately press the Lock button. That simple procedure gives a snoop full access to the Phone app on the iPhone, which contains the address book, voicemail and call history.
Mar 19, 2013 | Apple iPhone4 4G iPhone 4
I forgot my iphone voicemail password, how can i just erase so i can make a new one.
  1. Call 611 or 800-331-0500.
  2. Press 1 to use existing number, or enter the wireless number starting with area code.
  3. Tap the 3 key to "get help with voicemail." (5 for enterprise customers)
  4. Tap the 3 key to reset your VM password.
  5. Enter the Billing Zip code for the account.
  6. A temporary password will be sent via SMS
  7. Access voicemail with this temporary password.
After performing the above steps, my voicemail was accessible once again, and I didn't appear to have lost any prior voice mail messages. AT&T's support page has several other options available as well, but I found the above to be the quickest and easiest to execute directly from my iPhone.
Jan 31, 2011 | Apple iPhone 3G
Unexpectedly, my voicemail has a password. I have no idea how that happened but I can't check my voicemail without a password. Not available in "settings" to change anything it remove this...
Hi, you'll need to restore your iphone as a new iphone it will wipe all the data from your phone but its necessary as if you try to restore your phone and use previous back ups it will bring the voicemail password back...Hope this helps..
Use the following steps to restore your iPhone.
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 6SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new...
Dec 26, 2010 | Apple iPhone 3G
I had a voicmail that I had saved on my phonen I went to listen to it, it was automatically deleted. That is a very imprtnt voicemail that I needed. Is there any way to get it back?
  • Start by tapping the "Phone" icon on your iPhone.
  • 2 Next, access your voice mail messages by tapping the "Voicemail" icon.
  • 3 Look at your list of current voice messages. If you have any messages that are eligible for recovery, you'll see an item at the very bottom called "Deleted Messages". Tap on this to access a list of your deleted messages.
  • 4 You should now see a list of deleted voice messages. If you see the message that you want to recover, tap on it and choose "Undelete".
  • 5 Your voice message will now be sent back to the main list of current voice mail messages.
  • 6 Repeat steps 1-5 for "each" message you wish to recover. This may take time!
  • Read more: How to easily recover accidentally deleted iPhone voice messages ' eHow.com http://www.ehow.com/how_4707121_accidentally-deleted-iphone-voice-messages.html#ixzz1A0684OUB
    Aug 04, 2010 | Apple iPhone 3G
    My ipod screen is enlarged
    Your iPod Touch is not broken! You accidentally invoked one of the accessibility features which zooms the screen. This happens when you double-tap the screen with three fingers simultaneously. To undo it, double-tap again and drag three fingers up or down.
    You can turn this feature off by going to Settings > General > Accessibility > Zoom.
    Oct 20, 2009 | Apple iPhone Smartphone
    Home screen zoomed in, can't bring back to normal zoom
    I went to different post and I figured it out. Its so easy I feel like kicking myself. lol tap the screen with 3 fingers at the same time! Thats it problem solved.
    John Sanchez :)
    Aug 06, 2009 | Apple iPhone Smartphone
    Iphone 3gs the icons are very big and i cannot change them back
    I ve had the same issue today and freaked out thinking the phone was crasing. How ever after spending 3 hours trying every thing and aking on the web.
    when you double tap the screen it normaly zooms?? yes
    use 3 fingure tips to do a double tap!
    this will take a sort off large zoom screen lock off and bring the main screen fuctions back inline for you.
    please let me know or leave a reply
    :0
    Jul 28, 2009 | Apple iPhone 3GS Black (16 GB)
    Problem setting up voicemail
    Check the procedure is correct.
    1 Tap Voicemail, tap Greeting, then tap Custom.
    2 Tap Record when you’re ready to start.
    3 When you finish, tap Stop. To review, tap Play.
    To rerecord, repeat steps 2 and 3.
    4 Tap Save.
    Hope this helps
    Regards
    Apr 17, 2009 | Apple iPhone 3G
    My iphone camera just shows a black screen when i touch the camera app and wont allow me to take pictures what can i do
    pls see this First !! B4 reset
    Straight from Apple Iphone Manual
    Camera is not functioning
    1. Tap Camera, then point and shoot. Note: If you take a picture with iPhone turned sideways, it is automatically saved in landscape orientation. If you do not see Camera on the any of the multiple Home screens, check to make sure that Restrictions are not turned on by tapping Settings > General > Restrictions. If they are, set Allow Camera to ON or tap Disable Restrictions (in iPhone 2.1 software or later).
    2. If that doesn't work, clean the camera lens with the cleaning cloth that came in the box with iPhone.
    Mar 27, 2009 | Apple iPhone Smartphone
    Apple iPhone Smartphone Logo
    285 people viewed this question
    Top Apple Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Lesley Cameron
    Lesley Cameron
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
