Question about 2wire HomePortal® 1800HW Router (1000400212000LNR)
Modem speed Stream 5100 Router Home Portal 100 Would like to load a third computer on the network-Should be easy- Don't find it to be the case. It has been several years since I set up the network. Toidikire
  • 135 Answers
I might advise you to reconfigure the speed stream maybe there are some hardware lock ups inside to the router, Reconfiguring the router might fix your concerns.
Posted on Mar 09, 2009
The Wifi works (with my laptop) but my desktop
your laptop is able to go online using WI-FI.
desktop is connected to theb router but not able to go online. Do you see the port light on the router ?
check the Ip address on the computer. Check if there is any static IP address on the computer.
Click here for more information about the router and network
Jan 20, 2010 | Linksys WRT160N Wireless Router
Internet connection keeps dropping
is there any alternative on how to operate and install by our own
Nov 12, 2009 | Computers & Internet
CAN YOU SPEED UP A SPEED STREAM 5100 OR UP DATE IT
1: all you can do in a modem that really works is reset.
2: Another option if you upgraded your computer to vista or windows 7 from xp.. you might need to get a firmware update done by your internet service provider.
3: get a frimware update from ISP an will set up your internet speed unless its a problem from backend.
Oct 29, 2009 | Efficient Networks SpeedStream 5100 Modem
2Wire Home Portal 1100 for AT&T DSL connection problem
HI! read your posting regarding the situation that your experiencing.. If before you dont have any problem regrding your connection with out the cisco network magic. I suggest that before you install the cisco network magic. you should get the full version not the trial version, there is a limitation of setting up the trial version.. Cisco network magic is a plug and play and easy to setup if you get the full version. I dont see any problem regarding your connection with the 2wire and the linksys router, becoz you mention earlier that hime network is working and you can connect to the network and the internet..
Jul 24, 2009 | 2wire Computers & Internet
HOW CAN I GET MODEM ACCESS CODE ON SPEEDSTREAM 5100
hello
When you have modem plugged straight into computer, you can access it at 192.168.0.1, should ask for modem access code, (on bottom), then you can click 'advanced' > ppp location and set it for 'on computer'. There may also be a link for technician stats, it will give you info about isp connection. You should / might be able to browse but ISP may need original MAC address of machine (network adapter} you used when 1st signing up. Or if set to PPOE, it would look for name / PW in order to access INternet through ISP.
Anyway, try (after setting PPP on computer) Modem into WAN of router, access router, set PPOE > insert Log-in name / PW and save all settings. Then try homepage, if no, have router "clone MAC address" of the Network adapter you had the 5100 plugged into. Now it should work, even if no <INTERNET> light. ETHERNET light should be constant. Have router use DHCP to address machine independantly of what ISP addresses router, which it will do when modem (having connection confirmed with DSL light)
The other way, PPP location set 'on Modem', means the modem signs into ISP and then it assigns IP address with a timeout around 20 minutes. By getting connection test results when modem is connected to computer, it may seem to make sense, by understanding how ISP knows that modem access code / MAC address, and lets the settings of modem determine if router needs to sign in or not. If PPP is 'on modem', it will be looking for the MAC address of computer, that is why you may need to clone that address into router, so the router can appear as the machine to the modem, than the router assigns net address to computer.
Regards
Jul 09, 2009 | Efficient Networks SpeedStream 5100 Modem
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Router to connect or sub the speedstream 5100
Option 1 (easy)
you could buy a switch or router and put in line with your modem.
you will have to set up appropriate networking on the xbox
DSL --> MODEM --> SWITCH <-- PC
^---- XBOX
Option 2 (harder)
you could get a wired/wireless AP (Access Point) for your PC and run ICS (Internet Connection Sharing) through Windows. connect the XBOX through your PC
Aug 21, 2008 | Efficient Networks SpeedStream 5100 Modem
Speed Stream 5100 Modem -
You must use a phone company phone line splitter that is approved for DSL usage. If you use a radio shack or walmart phone splitter it will not work.
Aug 12, 2008 | Efficient Networks SpeedStream 5100 Modem
2wire HomePortal® 1800HW Router (1000400212000LNR) Logo
282 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
