Question about Watches
Eddie Bauer wireless thermo clock - Time zone problem
I cannot permanently set my Eddie Bauer wireless thermo clock 0465 to Eastern Standard Time. Every time that the radio control syncs with the atomic clock, it resets the time that I had entered to Pacific Standard Time. How do I permanently change the time zone?
  • 1 more comment
  • tjj88 Mar 27, 2009
    What a POS, why can't the atomic clock line up with the new time table?????
    I have multiple atomic clocks and I have to set them manually, what's the point?
    Can anyone fix this?
  • divenut Mar 31, 2009
    Same problem time won't stay at my time zone. If anyone finds a fix to this please post it. I am waiting on a reply from Eddie Bauer. I will post if they give me a fix.
    Jay
  • purdyrns Apr 06, 2009
    Thank you very much Divenut. Your solution resolved the problem with the time zone as well as restoring my highly temperamental remote temperature sensor back to life!
    By way of clarification - the only keys that you need to use are the 'Mode' and 'Adj'.
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Posted on Apr 04, 2009
Mode and Adjust will fix your problem. To fix the outdoor temp. you may need to
use a paper clip on the reset on the back of the clock.
I wrote mode and adj on some painters tape and put it on the bottom of the clock.
I know I will not remember this in a few years when the batterys need replacing.
A big thumbs up for the internet that we take for granted.
Posted on Nov 06, 2011
I can not get the out side temp to come on
Posted on Nov 12, 2012
How to set time on seiko qhr017s travel alarm clock
Did you ever figure it out? I have the same problem. I see no one answered you here.
Feb 09, 2014 | Gift Warehouse Seiko Silver Tone Atomic...
What is the 'CD mode' on the Eddie Bauer Travelinlg World Time Clock? What does it do? How does one set it?
The cd mode is a count down timer. Set it like you would an alarm then press the mode button when finished. Then press the up button to start the timer and then the mode or snooze button to silence.
Dec 27, 2010 | Watches
Set time zone on centrios atomic clock
1. In the normal time mode, Press MODE key to enter the alarm time mode .
2 Press SET key to change the time zone, P is pacific, m is mountain c is central and e is eastern.
Nov 26, 2010 | Watches
I have a Westclox, Calander Model 70026. I have set the clock several times to the correct time,(with the time zone at the proper setting) but, after a day or so, the hour reading, reverts back...
It's most likely because of Daylight Saving Time. Your clock receives a signal through the air once a day from the actual atomic clock, much like a cell phone receives the time from your cell phone service provider, and it automatically resets itself to the exact time each time it receives this signal. Remember that the middle of the year (the second Sunday in March until the first Sunday in November in the US) is Daylight Saving Time for much of the United States. The clock has an option that allows you to set whether you are observing Daylight Saving Time or not. If this is set to "off", the time will be one hour behind until Daylight Saving Time ends (November 7th). Make sure this is set properly, and your problem will be solved.
Sep 27, 2010 | Watches
How do I reset the time when I move into a different time zone
mcdevito75 here, You re-set the time in a different time zone the same way as you do for the time zone your in now. The different time zones in the USA ru from 1 to 3 hours before the time in the Eastern part of the USA, example, Eastern time 3 PM, then going West, you have Central time 1 hour before, then Mountain time, 2 hours before , then Pacific time 3 hours before eastern time.
Aug 10, 2010 | Timex Automatic Watch
I attempted to adjust the time of my WaveCeptor while out of the country and as a result it is now permanently 1:23 minutes behind PMT. The little LCD windopw shows the correct time, though. I've tried the...
This watch will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
RECOMENDATION:
You are likely out of range.
Adjust your time manually using the official time link below.
COPY OF YOUR MANUAL:
http://world.casio.com/wat/download/en/manual/
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
R/
David
http://antiqueclock.clockstop.com/
Mar 11, 2010 | Watches
I live in Eastern Time Zone. My atomic clock shows map of USA in top right hand corner and it is set in Western Time Zone. How do I reset to Eastern Time Zone? I have had atomic clock for several years. I...
The "mode" button is there to change the function of the + & - buttons.
If you press the mode button several times you will cycle through the various setting features of the clock.
Look for the one that sets the time zone and use the + or - buttons to select your zone.
Some experimentation may be required!
Feb 25, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
How do I enable the alarm on the Eddie Bauer world travel clock with flashlight? I can set the alarm time but I do not know how to enable it. I set it by 2 minutes ahead of the current time and waited for...
From the normal time position, press Mode and the AL function will come up which is where you set the alarm. Instead of pressing SET, press the up arrow. Each time you press the up arrow it changes function. When the alarm function is on a little bell appears above the colon in the time. The snooze has a ZZ that appears below the colon.The unique feature of this clock, is that it is the only one I have seen where the alarm works in the time zone selected. Most others, the alarm only works the home time zone, not the selected time zone. This is a huge improvement.
Dec 24, 2009 | Eddie Bauer Watches
Can't set time on my Eddie Bauer watch
Nothing on the net, so, you will have to go back to the store.
Sorry....
Dec 20, 2008 | Watches
Eddie Bauer watch.
these watches are waterproof so the stem is screwed down to seal out water. Try turning the stem to unscrew it somewhat , then pull out the stem to set.
Jan 05, 2008 | Watches
Watches Logo
3,228 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
