Question about Grundig YB 400PE AM/FM/SW Radio
Need a manual for YB 400PE - Grundig YB 400PE AM/FM/SW Radio
If you are looking for the User Manual, it can be found at:
http://www.scribd.com/doc/9196165/Grundig-YB400PE-World-Receiver-Users-Manual
Also, if you do a Google Search for YB400PE Manual, you will find many choices.
Best regards ... Hope this helps.
Posted on Apr 18, 2009
5 Suggested Answers
like what
SOURCE: Changing Time Setting
It is not intuitive, but the way to set the time is as follows:
1) be ready with your reference time - like your wristwatch with a second hand
2) make sure the YB is OFF (important!!!)
3) press the TIME I/II key so that you see the YB display TIME I. This is IMPORTANT!
4) you will be entering the time in 24 hour format WITH a leading zero if necessary!!!
5) at about 3 seconds BEFORE your time mark, key in the time with the following keystrokes:
H,H,decimal point,M,M
6) IMMEDIATLY press the TIME I/II key !!! This is VERY important!!!
You get only about 1 second of time to press this key after you enter the unit minutes.
If you miss the window, it shows an error or reverts to the wrong time.
The only way to sync the seconds is to time it just right with your reference.
If you want to set Time II, FIRST set Time I, THEN press the TIME I/II key to get the
display to show TIME II. Then you can enter the TIME II time in 24 hour format, H,H,decimal point, M,M, then TIME I/II. You don't have to worry about syncing the seconds for TIME II - it is locked to TIME I.
F.Y.I. -- This time I am prepared - I put these instructions on a sticker behind the folding stand on the back of the YB so I don't have to search for the stupid manual again!
Posted on Jan 27, 2009
  • 3 Answers
SOURCE: Grundig YB 400PE
Some Grundig models have a history of being friend by just small amounts of static electricity such as walking across a rug. It wipes out the tuning circuit.
Posted on Aug 14, 2009
  • 32 Answers
SOURCE: Grundig YB 400PE operating instructions
http://support.radioshack.com/support_electronics/doc69/69536.pdf there ya go
Posted on Jun 28, 2007
SOURCE: Replacement antenna
I drcided to replace the radio.
Posted on Oct 02, 2009
How to remove back cover on YB400PE
Did you ever get the Grundig YB400 open? If so please tell me as I can not open mine either!!
Feb 18, 2013 | Grundig YB 400PE AM/FM/SW Radio
Lost segments on freq display /?
Hi, problem is probably in connection between display and cable witch is plugged on him. You probably push too hard your display, or you dropped it.
Feb 25, 2011 | Grundig YB 400PE AM/FM/SW Radio
Moving home resulted in our loosing the AC adapter for our Grundig YB 400 PE, any sugestions where we could aquire a replacement?
its a 9V power supply
you should try Radio shack take with you the the radio to make sure the power supply have the correct connector
Aug 23, 2010 | Grundig YB 400PE AM/FM/SW Radio
Mine is a Grundig YB-2000 radio--and has just stopped transmitting. What's the problem?
Occasionally I've found dirty contacts, a crack in the board, etc. Try working the switches; check batteries and look for corrosion of the contacts.
But - this model is a receiver only. It's not supposed to transmit. If you had it transmitting, please tell me how. Marconi wants to know.
Apparently these sold as low as $30 at places like Fry's. At that price, it's not worth repair.
Nov 01, 2009 | Grundig YB 400PE AM/FM/SW Radio
Replacement antenna
Oct 01, 2009 | Grundig FR200 AM/FM/SW/DAB Radio
Nov 10, 2008 | Grundig YB 400PE AM/FM/SW Radio
Grundig YB 400PE
Aug 07, 2008 | Grundig YB 400PE AM/FM/SW Radio
Users manual for the grundig g5 shortwave radio
I can't find one either but there is a downloadable manual for the Eton E5 at Retrevo.com  Just search for Eton E5
Jan 24, 2008 | Grundig YB 400PE AM/FM/SW Radio
Buttons Don't Work
I would strongly lean towards factory service. Sounds like the circuit board has problems.
Good luck.
Oct 04, 2007 | Grundig YB 400PE AM/FM/SW Radio
Jun 27, 2007 | Grundig YB 400PE AM/FM/SW Radio
Grundig YB 400PE AM/FM/SW Radio Logo
689 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
