Bialetti Brikka Espresso Machine Logo
A
Anonymous Posted on Apr 11, 2013
Problem with the valve of Bialetti brikka - Bialetti Brikka Espresso Machine
1 Related Answer
Avi
  • 66 Answers
  • Posted on May 21, 2011
SOURCE: Need a copy of instruction manual for Bialetti
hey, screw the 2 parts tight and before that check if the filter plate is not clogged. See this guide that I wrote Avi
Bialetti Coffee maker repair
Sure it can. http://www.bialetti.com/coffee/stovetop/moka-express/spare-parts-c-1_7_22_32.html or http://www.amazon.com/s/?ie=UTF8&keywords=bialetti+spare+parts&tag=googhydr-20&index=aps&hvadid=32661633397&hvpos=1t1&hvexid=&hvnetw=g&hvrand=3217975301600862448&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_53u2x7ta30_b
I just purchased a Bialetti stainless steel 6-cup stove top espresso maker. I cleaned it, assembled it according to the instructions, and went to brew my first coffee. I didn't grind the coffee too fine,...
There is a valve in the compartment where you place your fresh, cold water. This valve must not be covered as it is necessary in building up steam pressure to push the brewed espresso upwards. Also, most stove espresso makers have a rubber type gasket that is usually placed on the base of the upper part of the maker. Check that you have a gasket.
I need a new handle for my GB Musa 6 Cup coffee maker. I am from Quebec City, Canada. Where could I get one of these?
It's a Bialetti Musa. The GB stands for Guido Bergna, the designer.
I haven't seen handles on any parts site, just gaskets and strainers.
You might contact Bialetti Canada, or Bialetti USA and get a handle.
CANADA
Toll Free:
800.667.4978
Mail:
Bialetti c/o Stonehaven Group
1880 Ellice Avenue
Winnipeg, Manitoba R3H0B9
email:
[email protected]
USA
Toll Free:
800.421.6290
Mail:
9409 Buffalo Avenue
Rancho Cucamonga, CA 91730
email:
[email protected]
[email protected]
Apr 05, 2011 • Vacuums
4helpful
2answers
Side valve is releasing pressure too early.brikka is 3 months old
check your filter plate to make sure it isn't clogged , that could make the safety valve do it's job and go off.
3helpful
I have just blown the valve on my bialetti cappuccino maker, can I reuse it?
The valve no, it is dangerous. Steam under pressure is a bomb. If you can detach ?unscrew? the old valve and find a new one, it will be fine.
1helpful
Brikka don't open!!
Three approaches to this: 1. Apply more force. Easier said than done, because these things, while elegant, are always an awkward shape. If you can't get a pair of rubber strap wrenches, you might try wrapping the bottom section in a couple of layers of cotton to keep it from getting scratched, and clamping it in a vice. Get a loop of cord, hook it over the lug the handle goes onto and stick a pole into the other end. This should allow you enough leverage to unscrew the top. 2. Pour boiling water into the top section, let it heat the top up a bit, then pour out the water and attempt to unscrew (in theory, differential expansion should improve the clearances and make it easier to undo) 3. Combine (1) and (2). A.
Top Bialetti Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
