Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Black & Decker electric mower, what are the plastic clips for?
We just took our new 9 amp mower out of the box and there are 2 plastic clips of some kind that we don't know what they are for. there were no instructions of any kind in the box, but the picture on the box looks like they might go somewhere down near the end of the handle. what are these for?thanks!
  • 313 Answers
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Posted on May 31, 2008
  • 2002 Answers
SOURCE: electric lawn mower slowed down then stopped working?
The carbon brushes on your mower have worn and, need to be replaced; order them from black & decker
Posted on May 21, 2009
  • 4 Answers
SOURCE: Black and Decker Electric Lawn Mower MM850 wiring diagram
I have repaired mines. It was found in the trash dump, just before street curb side trash collection. It is a very sophisticated lawn mower. It taken me a month to restore it. The problem is the housing is poor design and does not hold the pin switch securely. This is not a simple on/off switch. It is switch module with two momentary switches built in to it to work simultaneously. The hot is a normally open momentary switch and the neutral is a normally closed momentary switch. Two things must occurred simultaneously for the lawn mower to work. The AC hot has to close and the neutral to open. This is a split phase AC motor. The switch has four connectors to it. The first two has black wires to it, for the hot, that is normally open. The second two has a white wire and red wire to it for the motor's start up winding. The orange connects with the plug's white, neutral. A new substitute switch will be two individual momentary switch, one for the two black wires will be normally open and the two for the red and white wires from the motor start coil will be normally close. It will take two fingers to operate the lawn mower. I recommend you to buy a new and each switch from Black and Decker.
The problem with the system is not the switch, but the poorly designed switch box housing. Often, there is nothing wrong with the switch. I tested mines and it works fine. The problem is the switch box housing does not keep the switch in the correct position for the higher tension spring lever to press against it to operate. I use small washers to stack between the rear of the switch inside and reassembled the switch box upside down by turning the handle upside down, so the washers and switch do not fall out. Once I am finished assembling the switch box and position it on the handle, then I position the handle back to the normal top side and attach the handle back to the lawn mower. I am finished.
"Split Phase Motors
Split phase ac motors are widely used for low power applications as for example in oil burners, furnace blowers, garage door openers and major appliances. Such motors employ separate run and start windings connected in parallel across the acpower source. When the motor is initially energized both windings are energized, and when the rotor speed reaches about eighty-five percent of the normal running speed the start winding is disconnected from the circuit. Various devices are utilized forthis latter purpose and include centrifugal switches and current and voltage relays.
A problem which is characteristic of these motors is that they have a relatively short operating life. The principal reason for this is the failure of the switching devices used to cut out the start windings when the rotors approach the normalrunning speeds.Failure of these switching devices in turn cause the start windings to burn out.
One of the reasons for the failure of these switching devices is the high currents which they are carrying at the time the contacts open. Attempts to increase contact life by use of improved designs and materials have not been altogethersuccessful. Another disadvantage associated with these switching devices is that they are necessarily quite large and occupy a substantial space in the motor housing." -from another web site.
Posted on Sep 08, 2009
  • 23 Answers
looking down at the terminals, rotate push-button to the right. the wiring sequence is R, W at the top, then Black (in, from power source) , Black (out, to motor).
Posted on Sep 27, 2009
  • 52 Answers
SOURCE: Electric Lawn Mower Doesn't start - Pwr supply ok - No burnt Moto
this mower has a dc motor and the brush on the black wire to the motor usally wears down
Posted on Mar 03, 2010
How do you change a blade on a black and decker Rota-twin GR101 mower
my search shows that up as a
black and decker /flymo electric mower type
no picture on the parts list
of the rotating part being metal
two types of blade sets ...says its plastic and just clips on
is that for real ....plastic clip on mower blades
will this work
pull to the larger slot to release the old blade and back to the smaller slot to hold the new blade in place
Jun 15, 2016 | Cars & Trucks
Corded elec mower wont start. Extension cord is new
Is there power going to the extension cord? If so, is the power reaching the electric motor? If not check the on/off switch and connections.
Jun 28, 2015 | Black & Decker Black Decker 18" Lawnhog...
Elect mower blade replacement
mower, then blade, then plastic part, then metal square washer, then nut
Apr 23, 2010 | Black & Decker Garden
I have an electrical lown mower model LM 110 that as a broken plastic part under the blade but I don't have the manual to find the part number. Can you help me ?
IF is it a square plastic washer with 2 "wings\nocht" in the middle you can find at their servicenters because is a very common part and all the Black&Decker mowers use the same one. It holds the blade so you can thighten the nut.
Sep 18, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Black & Decker MM850 switch and arm pivot failure
The "wedge" of the plastic lever wears, so you need to replace the lever or build up that section of the lever. Some cyanoacrylate (Super Glue / Krazy Glue) and a piece of a zip tie will work.
Sep 15, 2009 | Black & Decker 19" Electric Lawnhog...
I have an old Black and Decker 18 electric mower that has reached it end of life. I don't have a model number, it has two 9 or 10 inch blades with belts back to the motor. It is an old orange version. I...
Here is the black and decker website:
Most the old models where 6 amps. 1/2 hp
You can get another one from ebay or craigslist
Sep 04, 2009 | Black & Decker 18", 6.5a Electric Mower
Replacement batterys for cmm1200 black&decker electric mower
You can find replacement batteries on amazon, click here and take a look: Amazon com Black and Decker 24 0 Volt Lawn Mower Battery 90508011. I hope this was helpful. Cheers
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Feb 06, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
55 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
