Question about Olympus SP-550 UZ Digital Camera
Olympus 550UZ won't turn on - lens problem?
My Olympus 550UZ won't turn on. It doesn't do anything, no blinking, no noises, nothing. It is NOT the batteries!!!!! I have made quite sure that the batteries work completely. The only thing I can see that may be contributing to the problem is an internal lens covering that looks like it is stuck open. There is no way to access the lens covering since the outer lens glass is covering it. Please help! I have had this camera for only 1 year and I am a very anxious budding photographer who wants to get out there and take photos again!
SOURCE: lens cover wont move
You probably didn't wash the camera after using it underwater specially in salt water. The salt will dry inside the lens and may cause this problem. Try soaking the camera for a while - wash it according to the manual's instructions. Hopefully soaking it will clear the deposits and clear the lens. Good Luck.
Posted on Jul 26, 2007
SOURCE: OLYMPUS SP-550UZ
When I try to zoom on my SP 550 UZ it says battery empty, yet operates normally otherwise.
Posted on Jan 04, 2008
SOURCE: How To Remove The Fixed Lens From The Olympus E-10 For Cleaning
The easy fix is to buy a new camera. Or trade up to Canon equipment that is easier to clean.
-BLL63
Posted on Sep 16, 2008
kakee
  • 1269 Answers
SOURCE: How to remove lens from
This cleaning process is very delicate and sensitive. Cleaning lens should be done by authorized or pro camera technician. I suggests you to bring it to the nearest cam service center because they have appropriate tools to open the camera and properly clean it. A single failure or error on cleaning it by yourself might give fatal result to your camera.
Posted on Oct 04, 2008
BillB-SA
  • 2761 Answers
SOURCE: olympus 770 sw lens cover not closing
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
Olympus VR-340 Won't turn on, lens won't retract.
My camera vr-340, when starts a sound appear and sacreen becomes black . what is this?
Jun 20, 2012 | Olympus Vr-340 16mp Camera Digital Optical...
My samsung TL220 i dropped it won't power on or anything
Things to check first for a camera that won't turn on (no power, no lights, no noise, nothing) are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
But if there is some electrical activity, then you're more likely experiencing a lens error. In that case, see this article.
and this video:
Nov 21, 2011 | Samsung DualView TL220 Digital Camera
The lens won't come out - it makes a buzzing noise but won't open. Like it's jammed?? Olympus FE-46
Hi.
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 04, 2011 | Olympus FE-46 Digital Camera
My Olympus vg120 switches on but the lens won't pop out. It makes a noise and tried to open but doesn't
Sounds like it has been dropped and is off track/set .As long as it wasn't broke electronic tech could fix it. Dont spend much tho cause they are around 75 bucks online now.
May 08, 2011 | Cameras
Is there a reset button on the Olympus fe -26? Mine froze and will not turn on, just makes a noise like maybe the lens is trying to move but nothing happens.
It seems is a lens erro for your camera, and none reset will helpful, and you can read these 2 article maybe helpful: lens error E18 and turn off and on again Commonly, there is something loose inside the lens, such as a screw. So when you try to start it, it makes noise.
Apr 30, 2011 | Olympus FE-26 Digital Camera
Olympus SP-550UZ camera will not upload recording to computer
Long videos should be transferred to a folder you create on your desktop using a separate card reader. eaa3d1b.jpg
Jun 15, 2010 | Cameras
How can you take off the lens on an olympus sp-550uz camera? the lens is stuck is not coming out
my camera wont take pictures clearly and on the screen the flash signal is blinking and next to it theres something that says E:91:01 how can i fix it
Oct 30, 2009 | Olympus SP-550 UZ Digital Camera
Olympus Stylus 710 Error: D: 5f08 5f0a 5e02 5f08 5e02
this is the most common problem with the olympus cameras the lens has been knocked and by you pulling on the lens it sounds like you have done some damage to the motor that bring the lens in and out thats why its making that noise what you needed to do was move the lens either to the left or the right you will no when its fixed because the lens just pops out and the camera will be fine this works every time i just hope you havnt done to much damage alredy goodluck
Sep 21, 2008 | Olympus Stylus 710 Digital Camera
OLYMPUS SP-550UZ
Oct 11, 2007 | Cameras
Olympus Mju 400 error code d: 1E12
the lens is with problems and needs to be changed. doesn´t happen when u connect to computer, because when is connected the lens doesn´t move.
Jan 21, 2007 | Olympus MJU 400 Digital Camera
Olympus SP-550 UZ Digital Camera Logo
164 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
