Question about LaCie (300740) 160 GB Hard Drive
Lacie D2 Hard drive extreme not working
I plug it in the computer and the blue light lights up just fine but on the inside you can hear the disk not beaing able to read, kind of a reacuring clicking soung and it doesnt show up on the computer and eventually it just stops. any one got a soloution where i dont have to send it in for repairs because the wipe the data off and i have alot on there thats very important to me.
  • Anonymous Mar 29, 2009
    You can hear the drive trying to spin and you have to keep turning it on and off a few hundred times.... LACIE??? NEVER AGAIN.... All my important data that took years to gather is in a crappy drive!!!!
    LACIE IS NOT QUALITY as far as I am concerned....
  • 6,831 Answers
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Posted on Dec 02, 2010
My Lacie Hard Drive only shows 9.99 mb capacity. and its a 2TB LaCie d2 Quadra v2.1 7200RPM U. It was just repaired by Lacie. Where's all the storage?
Please explain what you mean? When you plug in the drive it recognizes the drive but the size is showing to be extremely small?
Please let me know so I can help further.
Thanks!
EJ
Aug 05, 2011 | LaCie 2TB d2 Quadra Hard Disk v21
When I came back from holidays, the battery on my APS surge protector had died. I got a new surge protector: problem is, now my LaCie extreme d2 isn't seen on my desktop, so I can't back up. The blue light...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 23, 2010 | LaCie d2 Extreme 250GB External with...
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie d2 external drive
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
Sep 24, 2007 | LaCie d2 (300769) 200 GB Hard Drive
LaCie d2 Extreme Hard Drive
It could be that the drive is not formatted or initialized! Try this, right click on My Computer then click on Manage. Go to Disk management in the left pane. You should see all your disks that are installed in the right pane, it should show you their status. Actually if it is a new unformatted disk it should bring up the "Initialize Disk" window. If it does, follow the steps. If not look for a disk that is fully black (black means unallocated)then right click on the disk and Create a partition. The create partition wizard allows you to format the disk afterwards. If you plan to use the disk on some windows 98/ME machines you need to create a FAT32 Partition(FAT32 partition can't be larger than 20GB(20480MB) if not just format it NTFS(performs better and more reliable). Hopes this helps.
Mar 10, 2007 | LaCie d2 Extreme (300793U) 500 GB Hard...
Open Questions:
LaCie (300740) 160 GB Hard Drive Logo
144 people viewed this question
Top LaCie Computers & Internet Experts
Tony
Roshan Rijal
Roshan Rijal
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
