Question about Refrigerators
Refrigerator door keeps popping open
I have a 18 tfa refrigerator with freezer on topModel number et8wtexmq02.The door to the refrigerator keep popping open.How can I fix this the model was built in 2005
  • 38 Answers
Level refrigerator with front 1/4-1/2 bubble too high in front.
Posted on Mar 08, 2009
Freezer door opens
This sounds like an alignment problem. Loosen the hinges slightly and place the door in the closed position and duck tape it in place. Tighten the hinges and check it for seal. Door is heavy by itself so empty it first and work with some help.
Apr 01, 2014 | Maytag MSD2732GR Side by Side Refrigerator
The bottom freezer door on my Kenmore refrigerator 795.7900 pops open each time I close the top door. I have tried adjusting the leveling screws and it hasn't helped. Any suggestions?
Glen you keep adjusting but before that try to find this unusual problem. On its own, doesthe freezer door close witha thud? If not it needs adjustment otherwise other problems could surface.
Mar 03, 2014 | Kenmore 72912 / 72914 / 72919 Bottom...
Kenmore smart reach
What is the model number on the model tag?
Feb 13, 2014 | Refrigerators
Freezer door opens when fridge door is closed
that is common, your pushing air back into the other side and that pops the door. First adjust the ref so that the back sits lower than the front. It will have 2 5/16th nuts on the front behind the kickplate. going left will lower the back of the unit. After that get out some vasoline and lube up the flat sides of the door seal, this will help keep the seal moist and it wont pop open as easy
May 01, 2012 | Maytag Refrigerators
Freezer won't stay shut
If you want a part number for the replacement door gasket please provide a complete model number here so I can give that to you or you can look it up yourself at www.searsdirect.com You must have your model number. (sample 110.XXXXX etc)
The magnet is inside the door seal itself. If the seal is damaged replacement is your only option.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Refrigerators
Freezer door closing problem
to keep freezer door from popping open close main door more gently try extending front legs a little to help the door swing shut
Aug 04, 2009 | Refrigerators
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
Jun 17, 2008 | LG LRSC-26922 Side by Side Refrigerator
Banging noise from fridge
If i was in your shoes i would buy a new one,sorry,close,eire
Dec 16, 2007 | Kenmore 64192 / 64194 Top Freezer...
Refrigerators Logo
418 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
