Question about Linksys Wireless-G WRT54G Router
Linksys wrt54g2 router not allowing connection wirelessly
I have a wireless linksys router wrt54g2 and i am not being able to get onto the wireless network, i had it all set up but then there was a poweroutage, after the outage the network was nonexistent when i looked for it to show up on my laptop. my computer can connect to the modem and surf on the internet fine, but the internter will not go wirelessly when router is plugged in, i restarted the router to its original form and i was able to see linksys as a icon that i can go on but the internet still didnt work.
i hope i anwsered most of the questions but ask away if more knowledge of what has happened needs to be asked
  • Hal Burch
    Hal Burch Mar 10, 2009
    I have the same problem. my laptop can connect to the router with good signal but it will not access the net.
    Scholar:
  • 62 Answers
Try resetting the router then after it is successful just change the firmware to another one like dd-wrt it is much better and powerful.
You can get it at www.dd-wrt.com
thanks
Posted on May 24, 2009
  • 643 Answers
U can try reset the router back to default factory mode, then reconfigure again...
Posted on Mar 09, 2009
I ddont want to have a password any to my linksys router
You can turn off wireless encryption in the Linksys router. This is in the wireless settings.
If you turn off the encryption then your wireless router is open to anyone to use your Internet and access your network.
I recommend you do not allow this as it will cost you money when your Internet download limit is exceeded.
Mar 03, 2013 | Linksys WRT54G2 Wireless Router
What is wrt54g2 by definition
Linksys Wireless-G Broadband Router WRT54G2
here is a link for a review with lots of information and specs.
http://reviews.cnet.com/routers/linksys-wireless-g-broadband/4507-3319_7-32937120.html
May 20, 2012 | Linksys WRT54G2 Wireless Router
Download linksys driver WRT54G2 V1
What drivers do you want to download?
There are not drivers for Linksys router. It works on a software called as firmware?
How many wireless computers do you have?
What is the operating system on your laptop?
If your wireless network is secured then make sure that you have the correct network key.
See How to setup Linksys router
See how to connect to the wireless network
Mar 21, 2012 | Linksys WRT54G2 Wireless Router
Want to modify my settings
Documentation is at
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G2
But this page is way more helpful
http://www.pcwintech.com/wireless-setup-linksys-wrt54g2-linksys-firmware
From a browser enter 192.168.1.1
This should give you the web interface to your router.
Your interface should look something like this:
http://ui.linksys.com/files/WRT54G2/1.5.00/
To login leave user id blank and use 'admin' as a password (default)
Note that this model has at least 3 different variants and particulars will vary:
http://en.wikipedia.org/wiki/Linksys_WRT54G_series#WRT54G2
Jan 11, 2011 | Linksys WRT54G2 Wireless Router
I cannot access my WEP Hex Key, how can I locate it or reset it?
Connect to the router with an ethernet cable. Use a web browser and connect to 192.168.1.1 You should see a router home page. login as admin (default id= none/blank/null password=admin) These detailed instructions may help here http://nabtron.com/forgot-linksys-wrt54gr-password-how-to-reset-settings-of-the-router/180/ browse to the wireless/wireless security section and set up your WEP key. You can preview the web page layout here; http://ui.linksys.com/files/WRT54G2/ e.g. http://ui.linksys.com/files/WRT54G2/1.0.00/WSecurity.htm for you this would be http://192.168.1.1/WSecurity.htm
Jan 08, 2011 | Linksys WRT54G2 Wireless Router
WRT54G2 wired desktop fine, can't connect to wireless.
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
Jul 08, 2010 | Linksys WRT54G2 Wireless Router
How to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 28, 2010 | Linksys WRT54G2 Wireless Router
Wireless will not connect to internet after installing XP Service Pack 3. Router is a Linksys WRT54G2, adapter is a Linksys WMP11. Router is set to "mixed".
Try upgrading the firmware for your routher and the linksys WMP11. Also try setting router to 802.11g instead of mixed to see if it connects.
Sep 29, 2009 | Linksys Instant Wireless WMP11 802.11b
Unable to connect to wireless router
I need more details. Have you called linksys tech support? If linksys cannot help you try this http://technicalsupport.blog.friendster.com/
Feb 12, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-G WRT54G Router Logo
158 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
