Question about Ovens
Oven door won't close tight - light stays on
Kitchen aid oven; about 8 years old; excellent condition; material for door seal is in excellent condition; all of a sudden the door won't close tightly; was moved about 1 1/2 years ago and was working fine.
  • 38 Answers
Replace door hinges.
Posted on Mar 08, 2009
Kitchen aid oven /range model # kgrt607hbl4
The "window" is comprised of two sheets of glass enclosed by a metal band. Heat expansion results in a less than perfect seal and admission of material thrown off by cooking. It is not practical to attempt cleaning it.
Jun 25, 2014 | KitchenAid Ovens
Kitchen aid KEBC278KSS stays on
can u plz tell in detail dat which typ of pin or plug does ur mp3 player hav?
Jan 12, 2013 | KitchenAid Architect Series KEBC278KSS...
MY Kitchen Aid Superba Oven door KERC507Y will not stay tightly closed, what can be done to fix this problem?
The only real fix is to replace the springs on the door closer. Sounds like they got stretched or bent. Usually you can replace the whole hinge in about 30 minutes and that should help.
Dec 29, 2010 | KitchenAid Ovens
Rosieres 4040DB cooker - Problem with oven doors
hi can you please give me a call re this... I have the same problem on my 4040db and I am keen to know if/how you resolved it, many thanks Simon 07787 511443
Jul 07, 2010 | Ovens
Kitchen Aid Double Convection Oven blows circuit breaker
the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Feb 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Nov 06, 2008 | Ovens
Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Oven Doors will not stay closed all the way
I think this is a cheapest and eat way to fix your oven doors... Otherwise there are 2 spring type locks of the door that starts getting old day by day ... You have to change the pair of lock only
Apr 05, 2008 | KitchenAid Architect® KEBS277S Electric...
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Ovens Logo
748 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
