Question about Maytag MER6772 Gemini Electric Kitchen Range
No power I touched the bottom element and lost power to the entire range. Is there a fuse somewhere?
  • Anonymous Mar 23, 2009
    we had a power outage and when power was restored my power will not come on in my control panel therefore leaving me unable to use my oven
  • Maytag Master
  • 3,361 Answers
Check the range circuit at your house fuse panel.
If it is tripped reset it.
Then check the range for a short circuit.
Posted on Mar 08, 2009
Tappan tef351ewc
Loose connection somewhere?Replace both elements,make sure connections are tight!
Jan 10, 2014 | Kitchen Ranges
Stove shut off and blew breaker. Once reset everything works but bottom heating coil. Had it checked, it works. No burnt wires in the back.
Check the oven switch. The bottom element is the main element while the top one is usually the grill element. If the breaker tripped there must have been an overload somewhere and you are possibly missing a connection or fused wire somewhere else.
Jan 22, 2011 | Kenmore Kitchen Ranges
I was baking and heard a pop sound and saw a spark before the oven lost all power? What happened?
OOOPPs - not good , If you saw or heard a pop noise + spark then something blew or shorted.
If the 'loss' was quiet then a fuse or circuit breaker can blow without noise or sparks.
This oven has 4 Heating elements (2 on Grill) 2 inside oven , as you were baking it sounds like a heating element.
As this is a US model I'm assuming you are close to a SEARS somewhere, because they advertise parts made for Kenmore -- try this link
Jan 19, 2011 | Kenmore 94210 / 94211 / 94212 / 94214 /...
The bottom element of our oven doesn't seem to be working, is there anything to check before replacing it? (Fuses, etc.) It is a smooth top range.
Check to see if the bottom element contacts are properly inserted in the electrical connectors.Also in certain modes only one or both elements will work.Refer to you OP manual
Oct 07, 2009 | Ovens
Hygena oven trips main fuse box when switched on
sounds like that element is getting a "hot spot",high resistance area, will oven operate w/o that element in place?you also could have a bare wire touching the oven case somewhere, if it trips w/o having anything turned on remove back cover and examine all wires and connections
Aug 14, 2009 | GE Spectra JBP78 Electric Kitchen Range
I have kitchen aid in the counter range, the bottom heat element is bad. The element has burnt and has a 3" piece that has separated. At the same time the oven stopped working the burners stopped working...
The oven element will not affect the top burners, Unless it tripped the breaker at the panel when the element burned it two. Is there power to the stove? The top burners have their own power and control separate.
Aug 01, 2009 | Kitchen Ranges
After cleaning MER6775AAB, upper oven has stopped working
See if the top heating element is open. Also check the switch that feeds power to the element.
Aug 28, 2017 | Maytag MER6772 Gemini Electric Kitchen...
Creda grill
check the breakers at the breaker box. they probably kicked out. turn off, then back on. see what that does. (be sure the wires aren't touching any bare spots this time).
Aug 03, 2008 | Creda C361E Electric Kitchen Range
Oven not heating up
can you see the bottom element?? if so usually , its obvious when the element goes bad, youll see the damage.TURN OFF POWER. 2 screws remove elemnet from the front 2 wires, plug in aa new one and your good
Feb 29, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Aug 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
233 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
