Question about Sharp EL-738 Scientific Calculator
Need help finding the CPT Button on the Sharp EL 738
I am given a problem to solve, but canot find the CPT button on the calculator.
Im suppose to enter 172500 FV
5 N
9 I
CPT PV = should come to 112,113
I see all the buttons but the CPT.
Please help.
Thank you
CPT does stand for COMPUTE, on other calculators this is the COMP button, same thing, different name.
Posted on Apr 15, 2010
  • UBCO Apr 15, 2010
    CPT does mean compute, which is shortened down to COMP on the Sharp calculator.
    To solve (or compute) your question, press COMP --> PV
With regards to your cpt button on theEL 738 that button comp that should fixed the problem and the answer you get will 112113.164
Posted on Feb 05, 2010
I have the same problem and I have been searching for a answer and it seems there is not one out there. By deductive reasoning I have come up with a theory. I think the CPT button stands for compute on Texas Instruments calculators. All other ones I have found do not have this button. I have an HP and it does not have this button either, but you do not need it. Just leave out the CPT and you should get the answer. The CPT is just an extra button to compute on Texas Instruments, I think. Try entering in everything in the same order, just leave out the CPT. Hope this helps :)
Posted on Apr 15, 2009
How do I operate the power of function on a Sharp EL 738
To switch the EL-738 off, press the 2nd Function button and then press the ON key.
That will switch off your calculator.
Aug 21, 2017 | Sharp Office Equipment & Supplies
Sharp el 738
If you are talking about the multiplication sign, look for a key marked with a cross. It should be in the same column as the other operations, between the subtraction (-) and the division keys.
Sep 29, 2013 | Sharp EL-738 Scientific Calculator
Using a sharp el-738 calculator to find square roots
To get a square root sign on the SHARP calculator press 2nd F 3 (you will see in orange the square root above the 3) then type in the number you would like to find the square root and press equals
Mar 31, 2013 | Sharp EL-738 Scientific Calculator
Calculating square roots using a sharp el-738 calculator
On the calculator press 2nd F 3 to get the square root sign, then type in the number you would like to find the square root of and press equals.
For Statistics, how do you use the choose function for calculations
This is your permutations key. Press 11 then second function button and then RCL button. Finally press 0 and equals.
Mar 12, 2013 | Sharp EL-738 Scientific Calculator
WHICH ONE IS THE SIGN FOR 'TO THE POWER OF' ON THE EL 738 SHARP CALCULATOR
It's marked "y-superscript-x" and is the shifted function of the DEPR key.
Oct 25, 2012 | Sharp EL-738 Scientific Calculator
Where is the fraction button for sharp el-738 ? thank you
The EL-738 doesn't have a fraction mode like some other Sharp calculators.
Feb 02, 2011 | Sharp EL-738 Scientific Calculator
Where is the button for fractions on the Sharp EL-738 calculator?
Jan 17, 2011 | Sharp EL-738 Scientific Calculator
How do you raise to a power on a Sharp el-738 business calculato?
I don't know about this specific calculator, but there is probably a button on your calculator that has a "y" with an "x" as a superscript (exponent). Or is could be reversed. But you wanted 2^8, you would push the 2 first, then the exponent button, then the 8, and there's your answer.
Good luck.
Jul 14, 2010 | Sharp EL-738 Scientific Calculator
Sharp EL 738 Financial Calculator TMV calculation
Firstly, can i recommend resetting the calculator (There is a reset button on the back). (Or in general press 2ndF MODE to clear all the saved data).
Set your MODE to BEGIN by pressing 2ndF FV.
press 180 N
press 9 i/y
press 2ndF I/Y - press 12 ENT (this puts in your compounding intervals).
Press on
press +/- 35 000 PV
press 446 659 FV
Press COMP PMT.
This should give you the answer of -819.23 as expected :)
Jul 18, 2017 | Sharp EL-738 Scientific Calculator
Sharp EL-738 Scientific Calculator Logo
1,041 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
