Question about Kitchen Ranges
I cleaned my cooktop and of course disassembled the burners. Replacing them, I found that I couldn't get the ignition to shut off on two of them unless I shut the burner off completely. However, if I leave out the middle element, the ignition does shut off. I've checked that the little air-holes are free, and indeed reamed them just to make sure. I believe everything is lining up correctly.
  • Kitchen Ranges Master
  • 3,361 Answers
You may have gotten the spark switches wet.
They are attached behind each surface valve.
Remove the valve knobs.
Take a hair dryer and blow hot air into each switch for several minutes to dry out the switches.
Posted on Mar 08, 2009
What wood cause a burner to ignite and will not turn off.
Is there an orange glow in the burner area when this happens? If so then the thermostat is not shutting the ignitor off and needs replacing. If there is no glow then the gas valve is not shutting off the gas and needs repalcing
Oct 10, 2014 | Whirlpool Kitchen Ranges
Spark module wont shut off once it has ignited. Do I need a new one
I would clean the electrodes on the burners really good, sometimes they seem not to sense heat from the burner and will not turn off the ignition system. Other times I fond bad grounds to the cooktop or outlet that can cause the same issue. The electrodes since heat from the burners to shut down the inanition system, also with out a good ground this system is impossible to work correctly.
I hope this helps
Aug 21, 2011 | GE Profile JGP636 Gas Cooktop
When I turn on a burner on in the front of the cooktop the nearby burner keeps trying to ignite and makes the "clicking sound"
Hi lmills189,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 22, 2011 | Thermador Cooktops
My whirlpool gas cooktop on sparks on left front burner. Model scs3014gq1
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 01, 2010 | Whirlpool SCS3014 Gas Cooktop
Gas igniters on all five burners keep sparking (JennAir CCG556B)
Try cleaning around all the ignitors at each burner. Look for build up of cleansing product and/or food. Sometimes all it takes is a good cleaning and removal of a buildup to solve this. Worth trying before replacing a bunch of parts!
K
Jul 30, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Ignition will not stop clicking...
Did you clean your stove recently? If the switches under the burner knobs get wet they will cause the burners to click. Unplug the unit or shut off the power for a day. Once the swithes dry, it should work normal.
May 05, 2009 | GE 30 in. Profile JGP932 Gas Cooktop
Igniters do not spark on one side of cooktop
Is the gas able to flow freely through and out of the bad burners? Sounds like they may be clogged somehow
Jul 11, 2008 | Jenn-Air JDS8850AAS Dual Fuel (Electric...
Gas cooktop
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
Aug 27, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
1 burner wont stop clicking on miele cooktop km 344
May 06, 2007 | Miele 36 in. KM342 Gas Cooktop
Kitchen Ranges Logo
77 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
