Question about Acer AL511 15" Flat Panel LCD Monitor
Please check signal cable message comes up on screen when I power on , then power saving mode. I have only just grab monitor from junk sale & only found a lead to suit , that is the only cable attached
  • 3 Answers
Its due to Cheap Cable
Cheap Cable has less wires in it.
And data wires are not present
only RGB color information available
Good Cable cost 3 to 4 times than cheap cable
Posted on Jun 18, 2009
When I powered the desktop computer up this morning, my monitor powers on, but the LG logo comes on then the message Analog Power Saving Mode comes up and the power button starts flashing and I still have...
The problem is that there is no signal from the graphic / vga card from the PC, check the cable connection from monitor to the PC, or the PC itself got error on memory card or grapic card. Try to clean/ firm the graphic and memory card socket/ connection inside of your PC
Dec 10, 2010 | LG Computers & Internet
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
When PC is not used, screen goes black, then Check Signal Cable
right click on your desktop.go to properties.in properties go to the screen saver tab.click on the screen saver tab.under the screen saver tab you will a tab called power.click on power.change you monitor settings there.let me know if it works
Sep 07, 2009 | Computers & Internet
No Signal message
This is a message the monitor displays when the video cable is disconnected or the computer has no video output. Could be the computer is simply entering power save mode. Does the screen come on when you move the mouse or press a key on the keyboard?
Dec 28, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Power save mode
Yes, you arent getting a signal to your monitor from your video card. Try replacing. If its onboard then the Mainboard may be bad. These machines are known by Dell to go bad and is covered under warranty, provided you still have it.
The message you are getting is coming from the monitor, not the P.C.
Its telling you you it went into power save since its not getting a video signal from the P.C. Check connections as well.
If your using any kind of splitter, remove it and connect monitor directly to P.C. to be sure.
Good luck
Nov 28, 2008 | Dell OptiPlex GX280 PC Desktop
I bought a lg lcd monitor, but when I connected it to my computer I don,t see any screen. If I turn the monitor off and than on, it gives me a message on the screen (digital power saving mode).please help...
Dear,
you please check all the cables of the minitor connected to the cpu or not. It might happen some time when you disconnect your signal cable of the monitor.
thank you
pradeep
you u have problem again then please remind us.
Jun 22, 2008 | Computers & Internet
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Power problem
That seems to point to a problem with your video card.  Try taking it out and putting back in.  The power saving mode message comes purely from the monitor and only means it isn't getting a signal.  Also check the connection to the monitor and maybe a different cable.
Oct 16, 2007 | Insignia D400a PC Desktop
Cornea 15" monitor
If possible, try a new video cable. If it does not correct itself with a new cable, the problem is not serviceable. Flat screens do one of three things: inverter will go out (no light), line input board signal failure and power supply low volts on 12v B+.
Mar 28, 2007 | Cornea CT 1503 (Black, White) 15 in. Flat...
Acer AL511 15" Flat Panel LCD Monitor Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
