Question about Philips Car Audio & Video
Unlocking code for a rover R770 car stereo model n.o 22dc594/60b serial n.o fg594fy1154702
3 Suggested Answers
  • 4807 Answers
SOURCE: unlock car stereo
Sorry....this code will only be available from your Main Rover Dealer or by using a Radio Decoding Service as it is not in the available database
Posted on May 11, 2010
  • 4807 Answers
SOURCE: lost radio code for rover r770 model 22dc594/60b
RG594FY1142501
Unfortunately the code for this Serial Number is not in the available database so will not be available for free or cheap from anywhere on the Internet.
Will only be available from your Main Dealer or a Radio Decoding Service only.
Sorry I couldn`t help any further
Posted on Sep 04, 2010
Testimonial: "thanks regforge , it was worth a try"
mikopeco
  • 23 Answers
SOURCE: Hi I need a code for my Philips R770 Rover
If it is the standard stereo unit fitted to the car from the factory then you need to call the car manufacturer to get the code. If it is not then you need to call the manufacturer of the stereo to get the code.
Posted on Nov 11, 2010
Philips r770 radio code
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your vehicle manufacturer's servicecentre and get them to enter this code for you.
May 10, 2012 | Car Audio & Video
Nov 11, 2010 | Philips Car Audio & Video
Lost radio code for rover r770 model 22dc594/60b fd prod 0600 111142501 rg part no xqd101260 phillips
RG594FY1142501
Sep 03, 2010 | Philips Car Audio & Video
I need the code to unlock the stereo in my land rover..?
I think its fairly standard across all Land Rovers. First of all you need a code. This was supplied on a credit card sized piece of card with the original vehicle. I'l assume its not to hand... Typically, you can source the code (which is specific to your serial number / radio) from a supplier such as this on eBay
http://cgi.ebay.com/Land-Rover-Radio-Code-Decode-Service-22Dc710-61B-61L-/380186172853?cmd=ViewItem&pt=UK_Audio_TV_Electronics_In_Car_Entertainment_GPS_In_Car_Audio_Players_PP&hash=item5884dc9db5
Code in hand, you are ready to enter it and unlock the radio.
You only actually need numbered button <1> and the two seek buttons that look like <| and >| .
When you turn the radio on, you should see it request <CODE>
Press preset button <1>. This should identify character 1 of the code.
Use one of the two tuning buttons (Seek up , or seek down - the ones with arrows going into lines) to move to the right number (0-9).
Press preset button <1> again to lock digit 1 and move onto code digit 2.
Repeat twiddling the upseek and downseek. Press button 1 etc .... until all four codes have been entered.
When you press <1> for the final time, if the code is correct, you'll get a two tone beep to confirm and the radio is unlocked.
If incorrect, you are progressively locked out (in doubling time periods).
Hope this helps.
May 15, 2010 | 1996 Land Rover Discovery
I need code for rover stereo model:alpine serial no:AL7RV630W1210678
Sorry...Rover Alpine codes are only available from the Main Rover Dealer or via a Radio Decoding Service
Apr 01, 2010 | Alpine Car Audio & Video
How to enter code for freelander 1998 Radio R770
Philips / R770 Rover Code Entry
Switch on the radio, the display will show 'C'
Press [P1] followed by the tuning button to rotate the first digit
Press [P1] followed by the tuning button to rotate the second digit
Press [P1] followed by the tuning button to rotate the third digit
Press [P1] followed by the tuning button to rotate the fourth digit
Finally if the correct code is shown on screen press the [P1] button to save the code.
Jan 10, 2010 | Car Audio & Video
Car radio code for r770 rover radio
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Oct 10, 2009 | Philips Car Audio & Video
Car Audio & Video Logo
54 people viewed this question
Top Philips Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Ben Slimene Aymen
Ben Slimene Aymen
Are you a Philips Car Audio and Video Expert? Answer questions, earn points and help others
