Question about HP LaserJet 3055 All-In-One Printer
HP laser jet 3055 document feeder jam
HP Laser Jet 3055 has a document feeder Jam.
How do I release the paper?
  • zabrocki Mar 13, 2009
    The document feeder has an impossible grip on the page.  I cannot seem to open it further or release it to get the document out.
  • Anonymous Mar 28, 2014
    Is the HP laser jet 3055 wireless
Document feeder jam
Posted on Jul 27, 2009
  • 24 Answers
Friend,
If the jam is in the ADF on top of the machine, you should simply open the lid over the ADF and pick out the paper there. If the jam is in the printer itself you can open the machine, pull out the toner cartridge and release the paper from the mechanism under where the cartridge should sit.
Hopefully I can attach an image:
[img]http://images.amazon.com/images/G/01/electronics/detail-page/lj3052-2-lg.jpg[/img]
//Al
Posted on Mar 08, 2009
My HP color Laser Jet 2600 printer has a paper jam
Jul 21, 2014 | HP Office Equipment & Supplies
Hp laser jet 5025 paper jam
Clear the paper jam...
Also make sure all the pick up rollers are not smooth, if they are replace them. Also make sure the tray is set to the right paper and not offset. A lot of times people slam the tray and it moves the setting bar.
Jul 09, 2012 | HP LaserJet M5025 Printer
Paper is jammed in my printer - HP Laser jet 3055 --- cannot seem to clear -- don't know how to get at the jam.....can you tell me how to lift the area where the jam is?????
The panel on the back of the printer should pop out and you can get to the paper jam throught there. Make sure you get all the peices out cuz sometimes all it takes it one very small piece of paper to make it not work.
Aug 26, 2011 | HP LaserJet 3055 All-In-One Printer
HP LASER JET 3030 DOCUMENT FEEDER JAM
Lots of luck with this one.
Pull the paper out (in the direction that it feeds) very gently.
If that doesn't work, then you have no choice but to pull it out any way you can,
but gently.
Dec 06, 2010 | HP LaserJet 3030 All-In-One Printer
My laser jet just stopped printing. the symbol
indicate paper jam light but not paper jam in it , some times it it works what shall i do
Dec 16, 2009 | HP LaserJet P2015dn Printer
Documnet feeder jam
Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
Print test page.
How is it now?
Sep 15, 2009 | HP LaserJet 3055 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
May 21, 2009 | HP Office Equipment & Supplies
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
2,281 people viewed this question
Seeker5211
Seeker5211
