Question about Sharp AQUOS 52" Flat-Panel LCD HDTV
Sharp Aquos 52 in. color is messed up
My color on the tv is screwed up. it is green and have fooled with changing the color with and cant get it back to what is used to. Any help getting it back to normal would be greatly appreciated.
  • marionbagget May 11, 2010
    How did the problem occur ? Were you changing something ? Did the change occur by itself ?
    Are you getting a regular picture with basically the red and blue missing ?
5 Suggested Answers
SOURCE: 52 inch aquos sharp tv
Just bought a 52" Aquos TV 27000/1 newest model for 2008 my husband is putting it up and said the non HD channels don't look real good. Is there anything we can do to improve the picture on the non HD channels?
thanks,
Cathy
Posted on Apr 04, 2008
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
  • 12 Answers
SOURCE: i dont remember my secret
Every tv is different. i would reccomend callin the sharp toll free number and asking.
Posted on Nov 25, 2008
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
highspeedsan
  • 61 Answers
SOURCE: sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
Posted on Apr 30, 2009
Sharp Aquos tv
If you wiah to get some details about flat panel television repair then check the following link.
http://electro-medical.blogspot.com/
Sep 21, 2016 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Need screws for the back of my TV.Wall mount screws for a sharp LC52D92U
If you have purchased a wall mount kit that will fit a 52" TV there will be screws included that will fit.
Mar 15, 2014 | Sharp Aquos LC52D92U Television
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Sharp Aquos TV that only displays a colorful grid.
your t-con board is failing call a tech to install a new one
Sep 19, 2009 | Sharp LC-60C46U LCD TV
Large red bar lower half of tv sharp aquos 52" 2.5 yrs old
some parts inside your tv is damage or short circuited. too expensive to fix or replace
Sep 08, 2009 | Sharp Televison & Video
Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Jun 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos lc-52se94u green screen
Apr 30, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Feb 28, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sharp AQUOS 52" Flat-Panel LCD HDTV Logo
79 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
