Question about Dakota 2786-6 Wristwatch
I purchased a Nat. Geo. Dakota watch in past fall..It was impossible to set. Paid a watch shop to set it....now it won't change to daylight savings time...nor will it change time zones when I travel. Basically, I hate it...could you possibly exchange it for something similar...that works or that I can understand? Thanks, cjadams@kc.rr.com
  • theberlons Mar 10, 2009
    I have a Dakota watch purchased from National Geograhic that worked for about a year but now it will not change to daylight savings time. The website customerservice@dakotawatch.com won't work.
    I am going to go to contact National Geographic and see if they will stand behind the waranty.
    Hank B.
  • 4 Answers
When changing time zones, your watch must be manually set for the new time zone you will be entering. This watch is not designed to adjust for new time zones automatically. Instructions for changing time zones can be changed using the directions found on pages 2-4 in your instruction manual. When changing to and from DST, your watch should automatically adjust for this difference with the next 24 hours after the change. If your watch has not adjusted, you may be in an area that is not receiving signal. Check if your watch has received signal by using the directions found on page 1 of your instruction manual. If your watch has received signal in the past and no longer is receiving signal, your watch may need to be serviced or exchanged. Please contact Dakota Watch Company Customer Service by email at customerservice@dakotawatch.com, or by phone at 1-888-459-0404.
Posted on May 21, 2009
G-shock casio 5034 won't beep when i need to change daylight saving
Module No 5034 won't beep except for alarm use.
Jan 23, 2013 | Casio Watches
Tip
How to adjust your Skyhawk for Daylight Savings Time (DST) *aka How to get UTC...
How to adjust your Skyhawk for Daylight Savings Time (DST) *aka How to get UTC to reflect the correct time when your local time is set*
According to Citizen's website FAQ, their watches cannot determine when daylight savings time goes into effect for all the different time zones so there is no automatic changeover from SMT to normal and back again. If you are on the winter side of the time change (fall back), you'll have to go to the set setting, one click out on the knob and cycle through all the timezones using the B button (the lower one) to change all the settings to OF (for winter) and in the spring change all of the appropriate timezones back to ON (for summer time). Disappointing, I know... for an otherwise great watch this would be my one complaint.
on Nov 17, 2011 | Citizen Watches
Dpfellside@hotmail.co.ukwhat is actually meant by daylight saving time. my Citizen watch always indicates this setting is off (I am in U.K.)
Daylight savings time is primarily an USA thing. We set our clocks ahead every Spring in March and hour and back an hour in the fall. The idea was invented by Ben Franklin centuries ago to save energy and it is still done with the same idea in mind. Read elsewhere to see how it saves energy, debatable. Not all part of the country observe DST. Just turn it off and you should be fine. You may need to correct the time.
Mar 23, 2011 | Citizen BL5314 52E WR200 Eco-Drive scyba...
How do i change the hour? Only goes 6:40 and 5:40. cannot go back to 4:30 or ahead 24 hours.
I think you are changing from DST (daylight saving time) to local mean time.
Presumeably your problem is that the watch is not telling you the local time.
As the watch is radio controlled you can only change the time by choosing the location setting, so that the watch knows where you are.
Press the "mode" button to select the location abreviation and use other buttons to change to your local city.
When you have set the location, press the mode button to return to normal operation.
Jul 16, 2010 | Dakota Watch Company Radio Controlled...
Need to change to Daylight savings time- automatic change did not happen
I need to change the current time. It does not change with daylight savings time, and I always have a problem setting it. Can you help me?
Nov 01, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
How do I rest the time for daylights savings
Given that it is truly a Radio Controlled watch, which it must be considering your description, it should reset itself tomorrow morning (November 1st). I would give it a day to change before becoming concerned. Again, your radio controlled watch should reset itself around 2 or 6 am on November 1st.
Oct 31, 2009 | Dakota Watch Company Radio Controlled...
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
Hourly alarm/beep
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Casio DW9052-1V Wrist Watch
Dakota 2786-6 Wristwatch Logo
623 people viewed this question
Top Dakota Watches Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Dakota Watch Expert? Answer questions, earn points and help others
