Question about Zenith B32A24Z 32" TV
Is this a digital tv? can i get a manual?
  • 59 Answers
If the set is over 2 years old it more than likely wont be a digital set. press the AV button that should switch you between digital and analogue if the set has digital in it
Posted on Mar 10, 2009
Is a curtis mathes CM19033S TV, digital capable (with digital antenna) or only analog?
To use this TV with a digital signal you need a digital to analog converter. Here is a link for a converter and one for the TV user manual.
Hope this helps.
Bob
Samsung CM19033 User Manual
Zinwell ZAT 970A Digital to Analog TV Converter Box for Antenna Use
Jan 06, 2015 | Curtis Televison & Video
Tip
Polaroid TLA-04011C Service Manual Download
Polaroid TLA-04011C LCD TV Service Manual Download
Have you misplaced your Polaroid TLA-04011C LCD TV Service Manual?
Would you like a digital, searchable version of the Polaroid TLA-04011C LCD TV Service Manual?
Follow this link (& click FREE) to download a digital version of the service manual.
I hope that helps.
_________________________________________
Polaroid TLA-04011C Manual Download
on Apr 30, 2010 | Televison & Video
Tip
Follow this link to download a digital version of the service manual.
I hope that helps.
on Apr 26, 2010 | Polaroid TLA-04011C 40 in. LCD TV
My EmersonEwf2006 was connected and programmed to a cable box. Trying to use this same tv now with an indoor antenna for local channels. Lost my guide book therefore I have no directions. can't get it...
Here is a link to a site where you can download the manual at no charge: http://tv.manualsonline.com/manuals/mfg/emerson/ewf2006.html. You will need a digital TV converter for that set. The US is now all digital for over-the-air (OTA) TV signals. If you have a digital TV converter, and have followed the instructions in the manual installing your indoor antenna and get no stations, you need a better antenna.
Jan 06, 2011 | Televison & Video
How do I connect my TV to my audio/video receiver?
The TV has a coaxial digital (SPDIF) output, and the receiver has two coaxial digital inputs available. Simply connect the TV's output to the receiver with the appropriate cable (shielded cable with RCA plugs) and select the input on the receiver. The TV manual says you only get digital output when watching a digital channel. The manuals for both your TV and receiver can be downloaded from the manufacturers' websites if you need copies.
Please take a moment to give this solution a fixya rating if it's been what you needed, and thanks for asking here!
Mar 12, 2009 | Sherwood Audio Players & Recorders
Is our Sansui tv #TVM1916 digital? How is it changed to digital?
I've ordered a manul for this tv. All I wanted was a simple answer to whether we need a converter box or if this tv is digital. Thanks.
Jan 24, 2009 | Sansui TVM1916 19" TV
Is my tv digital compatible or not
https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
Here are some general guidelines that may help:
TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
Owners Manual
Johstob...
For a Durabrand DWT 1304 Owners Manual, access TV Manuals Online here. You can easily download it. The manual is in .PDF format and showed exactly what I needed, how to delete a channel from the list.
I realize this query was posted a long time ago, but perhaps somebody else looking for the information will benefit from it/
Jim
Dec 08, 2007 | Durabrand DWT1304 13" TV
Zenith B32A24Z 32" TV Logo
108 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
