Question about Dryers
Model LDE303 has loud squeal when running - Dryers
  • psugi Mar 08, 2009
    mine is frigidaire electric fryer (gallery)
    when running it vibrates loudly recenty after 9 years operating perfectly
    can you help how to solve this>
  • 38 Answers
The most likley problem is the roller bearings on the back of the dryer, that support the drum.
Posted on Mar 08, 2009
At start up I have a loud squeal on my 99 Mazda 626. Both belts are new and so is the alternator. The squeal only last for about 10 secs or so and goes away. I have started it in neutral and the squeal is...
Does your car have air conditioning.? Most cars use the A/C compressor to dry the air for the defrost. It will also come on for a short time when you first start the car. With the engine running after the squeel has stopped , try turning the A/C on , If the squeel starts again , then I would think your A/C compressor is seized. Also . are you sure the 2 new belts are tight enough?
Feb 20, 2011 | 1999 Mazda 626
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Model LDE303 worked fine once we got the right
seems like the door safety switch is stuck. open door and look for it, a little dowel, see if it is clicking on and off. to test, open door, let the drier buzz and try pushing the little switch in and out.
Jul 09, 2009 | Dryers
Hotpoint Electric Dryer Model NBXR453EVOWW squealing when turned
Replace the drum support bearing at the rear of the drum.
Jun 11, 2009 | Hotpoint Dryers
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Whirlpool Ultimate care II loud squeal
The drive belt may be loose, and slips on the pullys as it goes into higher gear. It may need replacing.
Aug 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Have maytag neptune model # mde4000ayw.its elect.mod. mades loud noise when turned on and drum is turning.
IF IT IS A LOUD DEEP HUM WHEN YOU FIRST TURN IT ON AND GOES AWAY AFTER IT IS RUNNING, THE MOTOR BEARINGS ARE WEARING OUT AND WILL FAIL IN THE NEAR FUTURE.
IF IT IS CONSTANT SQUEALING NOISE, THE IDLER PULLEY OR THE DRUM SUPPORT ROLLERS NEED REPLACED.
Apr 06, 2008 | Dryers
LOUD SQUEALING NOISE
Most likely the rear drum bearing is worn. There's a "ball and socket" arrangement that supports the drum at the rear and a repair kit for it. Part #5303281153. Should run around $25.fe7bd93.jpg
Dec 27, 2007 | Frigidaire GLER341A Electric Dryer
Dryers Logo
111 people viewed this question
Top Dryers Experts
