Question about Briggs & Stratton Garden
Flywheel Key Keeps Shearing in Half
I own an Intek OHV 18.5 HP Briggs & Stratton engine on a Craftsman riding lawn mower. While mowing, the engine suddenly began to run erratically and backfire. I discovered that the flywheel key had broken; the main flywheel bolt was only hand tight when removed. I installed a new key & tightened the bolt. The engine started & ran perfectly for about 10 minutes, but when revved slightly began to run erratically again. Inspection revealed that the flywheel key had again sheared in half. what's the problem here with these keys? I don't have the flywheel bolt torque value, but suspect that it needs to be tighter, since the crankshaft where the flywheel attaches is cone shaped.
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
bbreton
  • 437 Answers
SOURCE: shearing of flywheel pin on starting 12 hp snapper
When you the key this time, put the flywheel on first then the key but this time use a little grit between the flywheel and crankshaft. Something like grinding compound. It will keep the flywheel from moving plus make sure you torque down the flywheel nut good.
HTH
Good Day.
Posted on Oct 29, 2009
  • 14 Answers
SOURCE: murray riding lawn moweer Need a diagram of how to attach a drive belt on a murray riding lawn mower 425613X8A DIAIGRAM
search google for diaigram
Posted on Sep 22, 2012
What is the air gap between the flywheel and coil on 22 hp
.030 (thirty thousands). I use brass shim material as it is not magnetic.
Jul 19, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Riding mower keeps back firing and will not start
you have a sheared timing key it is under thefly wheel replace says the red neck
Sep 01, 2013 | Briggs AND Stratton Intek Briggs &...
Need to know the weight of the motor oil
sae 30 in winter sae 40 in summer i preffer rotela
Aug 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Best oil to use in tractor lawn mower
Always use straight 30W oil in small four cycle engines if they are not liquid cooled. Use a brand name single weight 30 viscosity oil.
Mar 16, 2009 | Briggs & Stratton Garden
Garden Logo
1,378 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
