Question about HP Office Equipment & Supplies
My printer pull up several sheets of paper instead of one
My hp 560c deskjet has been loading four or five sheets of paper at a time instead of one, what can i do?
  • 24 Answers
You could try to clean the separator pad under the roller and ensure that the paper is placed correctly in the printer.. If this doesn't work, replace the printer, sad but true...
//Al
Posted on Mar 08, 2009
It seems my F2180 can not print photo paper. Are they too thick? I get paper jam all the time. Regards Loyd
Photo paper usually needs to be loaded SINGLE SHEET, or it will jamb, and this is commonly stated on the packaging of the paper...Just load single sheets, and no more problem.
Aug 28, 2011 | HP Deskjet F2180 All-In-One InkJet Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    Printer will not pull paper through and then gives an error message to reload paper but paper is already loaded.
    My suggestion to you is to clean the rollers. You can get a printer cleaning sheet from Staples or Office Depot. This should help.
    Jun 15, 2010 | HP Deskjet 3845 InkJet Printer
    I have a HP deskjet f4440. It says I am out of paper. I have loaded paper numerous of times, but it still says out of paper???
    This usually happens when the printer has not been used for a while. Try this: remove and re-install the gray plate from the back of the printer, then load only the necessary number of sheets for your printing job and lastly hold/push the sheets of paper gently forward while the printer is printing. This should solve the problem.
    Mar 28, 2010 | HP Office Equipment & Supplies
    The printer pulls the paper in towards the right and then jams
    This is most likely from bent paper. A lot of inkjet printers are really finicky about bent (even just curved) paper.
    Make sure your paper is stored flat.
    Fan your paper, then restack it prior to inserting the stack into your printer paper bay.
    Make sure the paper guide (small moveable bracket) is set to the proper paper width.
    Use decent quality paper.
    Make sure you keep several sheets in at a time, I've noticed that paper crumples more frequently when it's one of the last sheets in the tray.
    Following these tips will hopefully offer you the best outcome. Hope this helps!
    Jan 12, 2010 | HP DeskJet 5150 InkJet Printer
    Pulls in multiple sheets of paper
    you must not use thin paper. you should use thick paper so that it will only pull one paper at a time...
    Apr 18, 2009 | HP DeskJet 940c InkJet Printer
    Roller pulls several sheets of paper instead of one
    You need a separation pad for the paper tray. It would be advised to replace the feed rollers at the same time.
    In the short term, you can pull out the paper tray, and on the very front (where the paper feeds out), you will see a black (or gray) rubber pad that is spring loaded. Scrub this pad with a little alcohol, on a cloth. You can even rough it up a little with a brillo pad. This should improve the feeding for the short term.
    *please rate me :)
    Mar 31, 2009 | HP LaserJet 4650n Printer
    No installer of hp deskjet 560C
    I assume that you do not have the cd to install the drivers for your hp deskjet 560C...  I am providing the link for your where you can download everything about your printer...
    Driver and other details download link
    Above link does not work then use the below link:
    http://h10061.www1.hp.com/ccsearch/search?pname=hp+deskjet+560C&qry=Drivers&submit.x=7&submit.y=4&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=&productBigSeriesOid=&spid=&opname=&pname_desc=&ptype=&stype=&contextual_lname=&spname=&temp_hql=&search=0
    All the best... have nice day... :)
    Mar 18, 2009 | HP LaserJet 1018 Printer
    Top light with (x) blinking
    Fixed this problem this morning by unplugging the printer from the computer, plugging it back in and changing out both cartridges (color and black) and replacing with new cartridges.
    Don't know which helped. I had been unplugging the computer from the power source but not the printer from the computer.
    My four year old printer is still cranking - good open forum you provide here. Thank you !
    In that spirit, I decided to contribute my update ..... Judy
    Sep 12, 2008 | HP DeskJet 5550 InkJet Printer
    59 people viewed this question
    Seeker5211
    Seeker5211
    mukhtar21 shaikh
    mukhtar21 shaikh
