Question about Sport & Outdoor - Others
My 4-wheeler seems to not catch any fire..
When i turn the key on and push the start button it trys its hardest to start but i just wont catch.last night i changed the spark plugs and that didnt work..ive had people tell me that somethings not gettin air or the compression or somthin..but i need help bad..since 10:00am 3/8/09 ive been tryin to figure out wats goin wrong and makin sure that all of the plugs and wires are connected right.idk wat to do guys..can you help me please????
Get a screwdriver and find your cylinoid. there are two bolts coming out the top. touch both bolts w/ the screwdriver and the key on. it should crank your for wheeler. this is just the way us country boys do it.
Posted on Mar 16, 2009
Ktm 450 2011 wont start up electrical problem?
Check the coils if it is fine change sparks plugs should solve the problem
Dec 17, 2017 | 2011 KTM 450 SXF
Why doesnt the plug fire ?
whats a fill pump!!could be numerous reasons for no spark. check distributor,rotor button and check coil ect.
May 22, 2012 | 2000 Mazda MPV
Engine won't start-- it trys -seems like it may not be getting fuel. Sprayed carb cleaner and it fired up--until it was used up
fuel pump, or fuel filter, turn the key on and off a few times and there is a valve that looks like a tire valve on the fuel rail push on it and see if it has pressure. if it has lots of pressure it is an electrical issue with the injectors if it does squirt out it is probably the fuel pump
May 22, 2010 | 2000 Oldsmobile Alero
Hi i have a 1998 yamaha warrior, loosing spark
Go on ebay and buy a new CDI computer those bikes are notorious for computer failure.
Aug 27, 2009 | RTO Quads 125cc Full Size Adult 4 Wheelers...
Car trys but wont start
Might be bad gas or it sounds like your fuel pump is out. It doesn't cost very much but I think it is located in the tank itself. Drain the tank and discard the old gas. take down the tank and replace the pump. This should fix your problem.
Jun 17, 2009 | 1999 Dodge Stratus
Yamaha timberwolf wont start unless push started
You have a loose connection to the ignition system . When cranking make sure it is in neutral. and kill switch is in run position. The only thing dropping would sensibly affect is the fuel system or jarring a switch., but with the suspension you have there really is no jarring. So, I would ck the wiring. something is loose.
May 29, 2009 | 2003 Yamaha YZ 250 F
1995 civic
There is a possibility that your timing belt has a couple of teeth missing now. When was the last time the timing belt was replaced? The reason for the fuel smell is the engine is trying to fire at the wrong time. It's trying to fire when the exhaust valve is actually opening. Replacing the belt isn't a bad job.
Jul 03, 2008 | 1995 Honda Civic
Sport & Outdoor - Others Logo
131 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
