Question about KitchenAid KUDM01TJBS Dishwasher
How do you remove the upper dishwasher rack? It's
How do you remove the upper dishwasher rack? It's a Kitchenaid dishwasher.
    Problem Solver:
The upper rack is held by four side brackets. They are not removable unless you pull the dishwasher out from under the cabinet. Not very homeowner friendly.
Posted on Jun 22, 2009
Need to replace the adjuster and need instructions how all the parts go together.
Replacing Adjuster Wheels on a Kitchenaid Dishwasher ...
? 2:50
https://www.youtube.com/watch?v=ClCHpDL--Gw
Jan 26, 2014 - Uploaded by natifamily
Replacing Adjuster Wheels on a Kitchenaid Dishwasher. natifamily ... Dishwasher Top Upper Rack Adjuster ...
Whirlpool, Kenmore, KitchenAid - Dishwasher Replacement ...
Nov 29, 2015 | KitchenAid Architect? II S SERIES KUDS03FT...
How to remove the upper rack on kitchenaid dishwasher
The upper rack has a captive washer with a lug that stops the top drawer from falling out. Use a torch, identify the captive washer that is connected to the rear wheel on each side if the drawer, remove these and the draw will come out
Jul 15, 2014 | KitchenAid 24 in. KUDP01FL Built-in...
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
Advice on removing upper rack needed thx
you may want to refer to the assembly diagram and see how the wheels and tracks are aligned. This should help you guide the rack out of the track.
Good luck.
May 13, 2011 | KitchenAid KUDM01FK Dishwasher
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Nov 13, 2009 | KitchenAid Dishwashers
Need an upper rack for a kitchenaid kdi21a
WHOOPS - turns out on that same diagram #24 is actually the top baaket.... and is $230.
I would think you could get an entire dishwasher for that price :D
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 23, 2009 | KitchenAid Dishwashers
Upper rack dishes not cleaning well
Yes, run an empty load with 1/4 cup vinegar. It sounds like there is mineral build up in the arm. Try to take the arm apart that supplies water to the top rack of the dishwasher. You can soak this in vinegar water once removed.
Jan 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid KUDM01TJBS Dishwasher Logo
533 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
