Question about Memorex MVD2042 DVD Player
My DVD Pler loads but in aminute or so it says no disc
My memorex 2042 loads but then says no disc. I cleaned the lense but
still doesn't work
  • Memorex Master
  • 13,433 Answers
Try another disc, does this happen with all discs? the optics are most likely failing, did you try a DVD lens cleaner and also try canned air?
Posted on Mar 08, 2009
Lite on burner will write but cant read
Now I LIKE Liteon very much. THey never give me any trouble and as long as you keep the lense clean, they burn for years upon years to come. Okay, so it CAN write, but can't read? Very odd indeed. I would strongly suggest first buying a CD Lense Cleaner disc. Don't be cheap. Get Memorex or Scotch 3M. I would Suggest Memorex because the brushes on THAT disc are SPECIALLY-designed to clean the lense, but NOT to damage it. Next, try installing Nero Ultra Edition and do a Burn-in or a Read/Write test with a CLEAN CD or DVD and see if it will tell you the Read/write data rate. If the lense is just a BIT dirty, it WILL give you those kind of problems.
Mar 25, 2014 | Lite On Computers & Internet
All DVD's that I put in the Memorex 2042 will pause at some point, then continue playing
It may be the laser cradle rail is dirty or requires a little oil. Inside dvds the laser sits on a little rail which it drives along as it reads the dvd, this can become dry causing this problem. The cure, try a tiny smear of light oil but dont get any oil anywhere else, unplug from mains first, also clean laser, you can get laser cleaning discs cheap.
petr
Nov 08, 2010 | Memorex MVD2042 DVD Player
Need Memorex MVD2045 5-digit remote code
This code worked for me with the Comcast DVR-3 and the Memorex 2042 DVD player: 20831
It may work with the MVD2045 as well.
Jan 17, 2009 | Memorex MVD2042 DVD Player
Memorex m v d 2042 is locked
unplug for 5 minutes and it should reset itself!
Dec 17, 2008 | Memorex MVD2042 DVD Player
My Memorex MVD 2042 won't open for me to insert a disk.
Mine did the same thing. I unplugged power, took off bottom ( seven screws on mine), took bar off covering lens ( two screws) cleaned rod that the door slides on with q-tip damp with rubbing alcohol. dabbed the rod afterwards with machine oil put everything back and now it works!
Nov 13, 2008 | Memorex MVD2042 DVD Player
Memorex MVD 2042
Me too. Only for Double Layer DVDs.
Mar 21, 2008 | Memorex MVD2040 DVD Player
DISK PROBLYN
When you get no disk error, that is because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others. Often the problem get worse in time.
Try first using a DVD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the DVD lens, or the whole drive unit.
Feb 07, 2008 | Memorex MVD2040 DVD Player
MEMOREX MVD2040 UNLOCK CODE
This is all I could find ..... Memorex DVD-2000 C/P / MVD-2020 / MVD-2022 / MVD-2027 / MVD-2027 A / MVD-2028 / MVD-2029 / MVD-2030 / MVD-2037 / MVD-2051
  1. Open the disc tray
  2. Press CLEAR
  3. Press 1, 3, 6, 9
  4. Enter region (0 = multi-region)
  5. Close the disc tray
  6. Turn the player off
Memorex MVD-2042
  1. Press OPEN/CLOSE
  2. Press 9, 7, 3, 5 (or 1, 3, 6, 9 for the "suffix B, C, D" model)
  3. The setup menu will appear
  4. Press RIGHT to move the cursor to highlight the regions
  5. Select region using UP/DOWN (0 = multi-region)
  6. Press ENTER
    (or try the instruction for MVD-2020 above)
Memorex MVD-P1072
  1. Turn on the player (without a disc inserted)
  2. Press SETUP
  3. Press 9, 2, 1, 0
  4. Select region (0 = multi-region)
Jan 16, 2008 | Memorex MVD2040 DVD Player
My Memorex DVD Recorder (MVDR 2102) won't open
Most likely one or more capacitors on the main board went bad. I just fixed one last night with the exact symptom.
Dec 15, 2007 | Memorex MVD2042 DVD Player
Memorex MVD2042 DVD Player Logo
145 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
