Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Need a Manual for Mcclough Model CS38EM - McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
I have a McCulloch CS38EM Why is the auto oiler not producing oil to chain. The port seems to be clear.
There is a spiral ring that drives the oiler on the crankshaft. Sometimes that slips and no longer turns the oiler. You can move it back and put a few drops of thread locker on the shaft before you place the spiral in place.
Oct 28, 2016 | McCulloch Garden
Need a/ manual
YOU NEED JUST ANY MANUAL? Or maybe a manual for some specific make and model?
Actually, if you need a specific manual, you can get if by searching with Google, using terms
Manual, Make and model of your phone
Jul 31, 2015 | Lands Phones
I need owner's manual
If you need ower's manual for an unspecifieed phone, please tell make and model.
You can do a google search yourself with terms manual, make and model.
Superstar Expert Achievement Badge Fixya
need owner manual
All Star Expert Achievement Badge Fixya
Jun 25, 2015 | Lands Phones
How do I fix a McCulloch CS38EM chain oil system - the plastic tube with filter on one end in the oil reservoir is adrift.
well your right the tube is supposed to be conned on one end to the pump , its at the far end of the tank , there should be a small barb down there to connect it to , I use a small piece of stiff wire to guide it to the pump , and a simple press and on it pops , of course you have to temp remove the filter off the end to do this , but that's easy to pop back on from the mouth of the oil tank once you got it back on, as for the oil in the case , I think if u read the operators manual , it clearly says to remove all fluids before storing saw , this means to remove all gas and oil from both tanks , I use old jelly jars for this , there perfect size to hold whats in tanks , leaving the gas in the saw is sure gonna give you troubles in starting it next time as well
May 13, 2015 | McCulloch Garden
Manual for McCulloch chainsaw # CS38EM
search with google, and most times you will find it if patient.
Jul 08, 2014 | McCulloch Garden
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
What are the carb. adjs. on a Mc culloch chain saw model cs 38em
If it bogs down like it's getting too much fuel, turn the low side screw out about 1/8 of a turn at a time until it will rev without bogging. If it chokes down like it's not getting any fuel, you probably need to open up the high screw a little.
BTW, you can determine which screw is which by looking at the carb at the base of the screw...it will have a L for Low or H for High stamped near it.
Jul 18, 2010 | McCulloch Garden
Throttle Adjustment Hi/Lo idle Calibration
it could be the air to fule mix wrong but if it runs ok i would take a good look at the chain teeth if there even a little bit blunt take a file to the chain and tuch them up,,,,a blunt chain is very power sucking,,pluss you need to pull the chain through the wood,, a sharp chain dont need to be pulled it will cut well just under its own whaite
Jul 01, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Where can I get a free online service manuel for this chain saw Model CS38EM. The chain got jammed and I've stripped it but now problem to reassembled it in original order.
I thought it was electric. Now I think it is a MTD McCulloch. A McCulloch example of model number "21-600038-76" follows (may not be your saw):
http://www.ordertree.com/modelinfo/MCC/21-600038-76-Mac-3816-IPL-211318-01/139.21-600038-76-Mac-3816-IPL-211318-01.1.59.1.html
A less detailed IPL that includes other 600038 models follows: Page 1 is illustrated, does it look like your saw?
McCulloch MTD
Chainsaws 32cc-35cc-38cc Anti-Vibe
This explains construction of an IPL number, MTD and Husqvarna models often deviate from the explanation.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
All McCulloch IPL may be found here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
Download and open the link below for bar installation:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1150046-95.pdf
See page 16.
This (bottom) explains chain installation.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 20, 2010 | McCulloch Garden
Cs38em... no spark
disconnect the kill switch first...
open circuit-->engine runs
close circuit--> engine shut down
try to observe any leakage along the spark plug line..
do not wrapped the leak in tape,it does not work...
u have to wrap the line with a rubber hose,find hoses that fit tightly outside the plug cable...
Jul 09, 2009 | McCulloch Garden
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
1,924 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
