Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 washer leaks
My five year old Bosch Axxis WFL 2060 frwasher has started leaking at the lower left corner. Have reduced the amount of soap used and still have problem. Not leaking from water supply hose or drain. Bosch repair came to my house and said they cannot see a problem and will need to take it into the shop to diagnose and fix. Anyone had a similar problem and fix??
  • Minimami Apr 05, 2009
    I just found the floor damp in front of my Axxis washing maschine :-( and can't find the leak. I am running a new load right now and will try to observe very carefully to see where it's coming from - just what I need to do on a Sunday afternoon...
  • Anonymous May 13, 2009
    My machine is about 7 years old and has leaked on and off.  Last week it leaked again and when finished I tipped it up to see if I could figure out where it is coming from.  Looked to me like it came from around the bottom of the drum and dripped down from there.  I believe I had it on a lower spin speed and a delicate cyle.  Would love to hear from anyone who may know what the problem is.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 21 Answers
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Posted on Sep 20, 2009
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch Axxis WFL 2060 front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Posted on Jul 23, 2013
  • 32 Answers
Would suspect inlet valves leaking or small hole in door seal.
Posted on Sep 06, 2009
2 Suggested Answers
  • 236 Answers
SOURCE: Is used Bosch Axxis WFL 2060 with door replaced a safe bet
not a bad price (poss a little bit high) but i would want to see it running on a warm wash first.
Posted on Mar 18, 2009
Bosch Axxis washer leaks underneath
take top off at back and check valve ,it should be at the top . Also check front rubber boot for rips, this is a big problem in all brands.
Nov 21, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Is there a container to put the detergent, or does one simply throw it in?
On the face of the top left corner you will see a BOSCH Axxis symbol. Pull that drawer out and that is where the detergents go.
If you need the manual, send me an email to LBrown18062@hotmail.com and I will send it to you.j02dnyo4yohv8f0skhh79tbeiaaaaasuvork5cyii=
May 13, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2872 washing machine that is leaking during wash/rinse cycle. Looks like it is due to rubber manifold between drum and pump - how difficult a repair is this?
Bosch WFL 2872 washing machine that is leaking This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
or it could be the seal
Oct 09, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Mar 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis Washer WFL2060 leaking when filling
yes.you are right.somethin might have cracked.
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Dec 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing instructions
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
Oct 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer leaking
First of all check the outer lip of the doorseal. It must be damage freein the lower half of the door opening. Then lift the folded part of the lip which faces towards the drum. Examine the doorseal with a torch. If any holes are evident the doorseal must be replaced. If you are in melbourne metro area you can call me on 0417362396.
Regards Sam
Jun 16, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch axxis 2060 mystery leak
We had a similar leak and it turns out there was a puncture in the gasket.
Mar 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
874 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
