Question about Schwinn Sierra DSX Adult Comfort Bike
Removing the crank arm off a shwinn sierra
Where the pedal screws into is stripped.I want to take it off, how do I do that.
    President:
  • 1,138 Answers
You will need a crank puller which is a specialized tool that does not justify purchase unless you plan on using it a lot. That means a trip to the bike shop which is a good idea anyways as they will have to match up the crank arm for you as they come in sets.You will also need a new set of pedals and there are lots to choose from.
Posted on May 09, 2009
There are no threads on the crank arm to screw a pedal on. What do you do now?
1. replace the crank.
2. Purchase a Heli-Coil or other brand at an auto store. It looks like a tube with threads on both sides that will screw in to the stripped hole and there by install new threads. Bring the pedal to the auto store to make sure it will thread in to the "female" threads on the Heli-coil.
The problem is the pedal is steel and the crank arm is soft aluminum. Also, people damage them because one pedal is normal thread and the other is reverse thread meaning you turn clockwise to loosen.
Jul 29, 2014 | Mongoose 26" Mens XR-75 Mountain Bike
Pedal stripped
You will need to have that crank arm replaced. They do make repair threads, but the price to install is just as much as replacing the crank arm. Your local bike shop can provide the correct parts.
Mar 28, 2014 | Schwinn Cycling
Stripped bicycle pedal
Better replace the pedal and most probably the crank arm as well. Sometimes a new pedal can cut the threads true again on the crank arm but the crank arm may need replacement too, depending on the damage. Remember to fit the correct side pedal. The pedal threads differ between left and right and pedals are usually marked "L" or "R".
Jan 04, 2014 | Huffy 26" Womens DS-7 Dual Suspension...
Recumbant bike makes aclunking sound whe pedaled
follow this steps and fix it. God bless you
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess grease
Loose Pedals
Kneel next to the left side of the elliptical's base. Use the Phillips screwdriver to tighten the two screws located in the center of the left pedal.
Use the Allen wrench to remove the bolt securing the left pedal arm to the pedal leg and body arm. Use the Phillips screwdriver to remove the screw securing the rear end of the pedal leg to the crank arm.
Pull the end of the pedal leg free of the crank arm. Wipe the crank arm clean, then apply a fresh coating of machine grease or silicone lubricant. Replace the end of the pedal leg back onto the crank arm and use the previously removed screw to secure it back into place.
Join the front end of the left pedal arm to the ends of the pedal leg and body arm. Use the previously removed bolt to connect the pieces together.
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm
Dec 09, 2013 | Exercise & Fitness
I have a NordicTrack SL710 recumbant bike that the pedals slip and make a clicking noise?
Prepareto oil by filling a grease gun with lithium grease. Check your owner's manualfor the exact type of grease for your unit.
Oct 31, 2011 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack SL710 pedals slip and make a clicking noise?
Kneelnext to the left side of the elliptical's base. Use the Phillips screwdriver totighten the two screws located in the center of the left pedal.2
Use theAllen wrench to remove the bolt securing the left pedal arm to the pedal legand body arm. Use the Phillips screwdriver to remove the screw securing therear end of the pedal leg to the crank arm.3
Pull theend of the pedal leg free of the crank arm. Wipe the crank arm clean, thenapply a fresh coating of machine grease or silicone lubricant. Replace the endof the pedal leg back onto the crank arm and use the previously removed screwto secure it back into place.4
Join thefront end of the left pedal arm to the ends of the pedal leg and body arm. Usethe previously removed bolt to connect the pieces together.5
Move to the right side of the elliptical and repeatthe above steps on the right pedal arm
Recumbant bike slips while peddling
http://www.youtube.com/watch?v=mVJxs7ALxDM&feature=related
Loose Pedals 1
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm.
Oct 30, 2011 | Nordic Track NordicTrack Treadmill, A2550
My proform 2605 elliptical the right foot pedal is making a loud noise like it's slipping.
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 01, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
My right pedal is stripped. how can you repair/replace the part the pedal screws into?
If it's stripped the crank arm will need to be replaced. It's probably more expensive to fashion a repair with helicoils and taps, even if you COULD find a left-handed one for the left side.
Get on your favorite search engine and look for "(your brand of crank) (size)" or just take it to a Bike Shop and let them deal with it. You would need special tools for crank removal anyway.
http://www.parktool.com/blog/repair-help/categories/crank-service
Jun 14, 2011 | Dynacraft Cycling
Pedal arm stripped and pedal will not screw in.
You Can go to www.huffybikes.com to order a new crank arm and pedal, go to the Support and than go to Missing a Part
Jun 13, 2010 | Huffy Girls Bike (20")
Schwinn Sierra DSX Adult Comfort Bike Logo
318 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
