Question about Maytag MGR5765QDQ CleanDesign Gas Kitchen Range
Handles fell off of the top oven door on maytag gemini glass top
I can not get the door apart to reattach the handle
    President:
  • 2,976 Answers
Open the door a few inches, to the first hold-open stage. Lift the door upward & off the mounting bars. There will be screws along the bottom edge.
Posted on Mar 08, 2009
Handle fell off. cant get to screws
There must be a way to attach the handle. My suggestion is to call the service center for that item and have them tell you how to reattach the handles which should not have come off in the first place.
Aug 10, 2012 | Toaster Ovens
On my Maytag Gemini MER6772 Oven in the top oven a circular disc fell off from the right side of the top oven exposing the insulation behind the oven. There is no way to reattach the disc, screws, flaps...
If there is no visible clips or tabs to hold the plate in position, the best way to reattach the disc would be to stick it in place using a silicone adhesive. Make sure that the plate is clean and free of grease etc, as also the back plate of the stove. Apply the adhesive to the plate, fit in place and hold it there with masking tape or similar for about 24 hours until the the adhesive sets.
Jul 04, 2011 | Maytag MER6772 Gemini Electric Kitchen...
H4080bm Miele microwave handle fell off
Hi Try not to open door with handle as this may cause to glass to smash. When you open the door you will see two pin sticking forward near the top of the door just further back on the top of the door is two small barbs push down on these barbs located in line but further back from the pins.This will release the top of the outer door.The bottom of the glass is hooked into the hinge. with the top released lift door glass away.You should find screw in inner door refit screw with some loctite.
Aug 23, 2010 | Miele H4080BMSS Oven
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Door handle is loose
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door. You will find the screws behind the panel.
If you have questions, please let me know. I hope this helps you.
Jul 13, 2009 | Microwave Ovens
MAYTAG PERFORM OVEN DOOR,THE HANDLE IS COMING OFF. HOW DO YOU GET THE DOOR APART, TO TIGHTEN IT BACK.
in your user guide it explains procedure to remove the door, after emoving the door and layingit flast on conter /table ita amtter of removing sccrews holding on glass, and top trim to get to the screws that holdon hanlde, a little patience is all thats required not hard here
Mar 06, 2009 | Maytag MER5755QAS CleanDesign Electric...
Cleaning in between the glass on the doors
The door will have to be removed an taken apart. Be very careful l with any seals and gaskets possibly even insulation and take note of where all screws and various parts go so that it all goes back together properly.
Jan 01, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven door handle
Lady, you are going to have to take the door apart to get at the handle screws. The whole door will lift off the hinges, place it down on a flat surface and go from there. You can find your manual with instructions at http://www.servicematters.com/maytag_library/docs/16010107.pdf
If that link doesn't work, go to servicematters.com, click on the Maytag section, follow the links, enter your model number and you will find your manual. Make sure to take your time, these can sometimes be a pain. Catriver.
Jan 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
How to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Maytag electric range door handle (how to replace?)
The above solution is fine, but you don't have to remove the door.  Open the storage drawer for access to the trim screws (3) on the bottom of the door, remove the screws.  Have a helper hold the glass along the bottom. Take the three screws on the top of the door trim out.  Slide out the glass and put in a safe place.  Remove the four screws that hold the handle brackets in place, remove the handle (or tighten if loose). Install the new handle (one screw on each side).  Reinstall all parts in the reverse order of disassembly.  The entire job took less than 30 minutes.
May 01, 2007 | Maytag MER5775Q Electric Kitchen Range
Maytag MGR5765QDQ CleanDesign Gas Kitchen Range Logo
420 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
