Question about Oakley GMT OAK0531 Wrist Watch
I have a athletics works AW60451W wrist watch that has gone to military time How do I get it back to civilian time
Go to the set hour function and cycle through the hours until you see the AM/PM display at the bottom of the watch face.
Posted on Apr 26, 2009
  • Robert Hull
    Robert Hull Nov 19, 2014
    but how do you keep it in 12 hour format?
How do I change from military time to civilian time?
After 12 noon take 12 hours off of Military time for hours in the pm
8 is 8am the 14 hours is 2pm
May 23, 2015 | Garmin Approach S1 Golf GPS Watch
Suunto core
go into the time setting mode and you will have an opportunity to select "12" or "24". 24 is military and 12 is civilian time.
Dec 25, 2011 | Suunto Core Watches
Athletic works watch that is stuck on military time
With my old watch (from Walmart), all i had to do was go into the time settings and cycle through the hours until it went past the military time's midnight and it would start going through "normal" AM/PM times.
I hope this is enough information.
Feb 15, 2010 | Watches
How do I get the watch to change from military
Get manual here from my tips and tricks.
Jan 24, 2010 | Timex 1440 Nylon watch
Athletic works aw60451w beeps on the hour. how do i turn it off?
hit the 2 buttons on the right at the same time (while in normal time mode)
Nov 09, 2009 | Watches
How do i get my athletic watch off of military time? It's a water resistant watch up to 165 ft. model # aw60447w
military time:
1. When setting the time on your watch, IF you watch can change to Military time(and most can)
2. when you are adjusting the hours go through a full 24 hour cycle. You'll notice that the 2nd time through it is on military time.. 3rd time through back to 12 hour day AM/PM cycle .. 4th time back to Military.
So you can do this as many times as it takes to get to the right time ..
In 24 hour time you will see an "H" displayed where you normally see and "A" for AM and "P" for pm.
Sep 23, 2009 | Watches
Athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Apr 30, 2009 | Watches
I have a Athletic works watch and I can't get it off military time.
When in the set time mode press the A button this will toggle between standard and military time. I had the same problem, dscovered it by trial and error, not in instructions.
Mar 27, 2009 | Bulova Watch
Athletic Works Watch
With time displayed:
Press lower right, then upper left.
Mar 12, 2009 | Oakley GMT OAK0531 Wrist Watch
Set watch
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
Feb 21, 2008 | Watches
Oakley GMT OAK0531 Wrist Watch Logo
1,065 people viewed this question
Top Oakley Watches Experts
Andrew Taylor
Andrew Taylor
The Scrivener
Are you an Oakley Watch Expert? Answer questions, earn points and help others
