Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Raypak CNG spa heater heeps giving RH 1 error code on touch pad.
  • boatingbob Mar 09, 2009
  • Anonymous May 23, 2009
    Same problem - RH1 error
  • 22 Answers
SOURCE: raypak 2100 digital heater give fault code eol
ILO or ROL. There is no EOL.
ROL is a switch inside the lower left corner of the heater. Press the red button. ILO is a lockout. Power down and power up.
Posted on Dec 21, 2008
PartsCenter
  • 125 Answers
SOURCE: I NEED TO KNOW WHERE TO HOOK UP THE WIRES TO A
Here is the Mfg Link so you can trouble shoot your heater.
RayPak
Posted on Feb 26, 2009
john224
  • 1378 Answers
SOURCE: raypak heater. fault cde says (ROL)
Thank you for posting your question here on Fixya.com.
Replacing the roll out switch is an easy do-it-yourself repair. Fixing the problem causing the roll out of the burner flames in the first place is a bit more of a pro job. Something is causing to much heat to roll out the the combustion chamber into the control area causing the switch to fail. You will continue to burn the link until the underlying problem is fixed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 01, 2010
  • 990 Answers
SOURCE: my raypak heater has error
This is in the limit string. This is the string of safty switches in the heater. (thermostat, highlimits, rollout switch and pressure switch) The pressure switch is the most common problem. If the water flow get's to be too little so the water inside the heater is going to overheat than this will shut the heater down. This can be caused if your heater by-pass is to far open and letting water go by the heater. The most common problem is clogged baskets or a dirty filter. Other than this you can follow the flow chart in your manuel to find the source of the problem but if it just started without obvious cause this would be my bet.
I hope this helped and good luck.
Posted on Aug 31, 2010
SOURCE: Raypak 2100 pool heater won't heat, PRS and HL2 error codes.
Well, I replaced the pressure switch with no joy. I tried all 5 levels of pressure 1-5 and every wiring combination. Finally, I returned the new $70 pressure switch and took the 2 wires and tied them together (jumped them). Here's the only downside...If you run your pump in backwash, recirc, waste, or any mode that would cause water to bypass the heater it MUST BE OFF. Otherwise, let it ride. It's working great and I hope to go into October weather permitting.
Posted on Sep 09, 2010
Cannot change to remote control touch pad does not respond
make sure hooked up to pool and spa common then put on t stat or remote
Mar 21, 2014 | Raypak Pool & Spa
I am getting a ROL code on my raypak 406 gas pool heater. Does anyone know what this means?
roll out senor bad replace but check gas pressure if too low it will overheat once gas is ok then replace fusible link and clean outside of het exchange
May 11, 2012 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
Ign error code on a raypak rp2100 pool heater
ignition failure check gas pressure if ok see if ignitor is ok or safety circuit
Apr 22, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
May 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 digital heater give fault code eol
Nov 22, 2008 | Raypak Pool & Spa
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
60 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
