Question about Kenmore 44102 Front Load Washer
Water collects in tumbler when I am not using the machine
Water builds and builds in the tumbler to the point where if I do not drain the water before opening it ends up all over the floor. What could this be and what can I do to fix this? Thanks!
  • 38 Answers
Replace fill vale. Fill valve is leaking water into washer. Fill valve is not closing all the way.
Posted on Mar 08, 2009
Water in bottom freezer
Sounds like possible defrost drain. Water builds up over time. Need to pull evap cover and see if ice is build up in tray. If so defrost drain, should fix issue
Aug 24, 2012 | Maytag MBF2258XEW
GLTF2940E not spin rinse drain problems
I would check the drain pump for objects. There is a trap that will collect coins and stuff. As this trap builds up it restricts/blocks the water from being drained from the washer.
Aug 07, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Ice build up in the bottom of the freezer compartment to the point that it will flow under the gasket like a glacier and melt. There is not an icemaker hooked up. No free water is piped to the unit and...
You have a common problem of a clogged drain, in the back bottom of the freezer, behind the shelf and drawers, you will find a drain pan that has frozen completely over with a ice sheet. This has caused defrost water to run forward and collect under your racks in the freezer. I would advice you to turn off unit, and remove all the ice collected in the freezer, clear the pan with warm water, then restart your unit back up.
Once the pan and drain tube is clear, your unit should be fine.
I hope this helps
Aug 02, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
I have a GE Front Loader. Model# GHDVH670H1GG. The tumbler works until water is required to be drained. At that time, the tumbler is trying to tumble for rinse, but, the water is not being drained and not...
On my machine the pump filter was clogged preventing the water from draining out of the machine properly. This would leave the clothes soaked in water as the machine tried to spin, the extra weight caused the drum to rub against the door seal while spinning, causing the burnt rubber smoke! I removed the 3 screws on the lower fron panel of the machine and opened the drain ( make sure you have a pan or bucket to catch the water! ) cleaned the fliter and put everything back. Works like new again. Good luck.
Sep 22, 2010 | GE WSXH208A Front Load Washer
Water collected in the tray under the air handler. The float turned unit off. Drained water and AC returned. What caused the water to collect in the catch tray. Is there a clog in the drain pipe?
Yes there is a clog in the drain, you can try a cloth hanger or a small drain auger, slug builds up and clog the drain it only takes a little to clog the flow and can easily be unclogged
Melvin
St Louis
Oct 04, 2009 | American Standard Heating & Cooling
Dehumidifier leaks
Either there is a hole/leak in the tray, or the drain line is clogged. You are giong to have to access the tray to determine this: standing water is plugged line and no water is busted pan. This will determine your avenue of approach.....
Aug 31, 2009 | Ebac Neptune Dehumidifier
Water pooling underneath bottom drawers
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
May 28, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Pump won't stop draining
you will almost certainly have a build up of water in the base. remove the water and retry. check to see if limit switch is not sticking or has possibly gone faulty.failing this, your board is faulty.
Sep 23, 2007 | Bosch 24 in. SHE44C05UC Stainless Steel...
Kenmore 44102 Front Load Washer Logo
27 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
