Question about Sony Computers & Internet
There is one hard drive for this computer, but the system in windows is showing two drives. One is drive C and the other is drive E. Drive E is only 2 gig and c is 30 gig, but there is a constent problem message of E drive being to low on memory space. How do I correct this problem? Help
    Problem Solver:
  • 10 Answers
You may have set the E (manufacturere diag drive) drive for system cache Check <start> <control panel> <system> <advanced> performance <settings> <advanced> virtual memory
<change> here you will see which drive has the system cache
It should (in your case) be C if not change it and system managed is OK this should solve the problem If not you can hide the E drive
<start> <run>type diskmgmt.msc Highlight the drive letter "e" with right mouse click select <change drive letter paths> remove the drive letter
gl :-)
Posted on Mar 11, 2009
3tb external imation expert d300 not working with windows xp
Windows XP does not have support for any disk-drive larger than 2TB. So, your 3TB disk-drive will not work. Upgrade your computer, or buy a 2TB disk-drive.
Jan 09, 2013 | Imation Apollo Expert D300 External Hard...
I have a verbatim external hard drive, model usb500 and my computer does not recognize it. I have it plugged into a working usb port and the blue light on the drive is on, but my computer isn't...
You need to assign a drive letter for it to show up in Windows.
Right click on My Computer, click Properties. Then go to disc management, and right click on your external hard drive, and click Assign Drive Letter, and choose a letter and it will show up in My Computer.
May 08, 2011 | Computers & Internet
My computer will not pick up my drive when i put it in
The windows disk management utility will help solve this issue most of the time. Use the directions below:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
If you found this answer helpful, please remember to leave positive feedback.
Thank You,
Brian
Mar 20, 2011 | Computers & Internet
In a Sony vaio the Fujitsu hdd reports an error and is unable to boot. When I hook the hdd up to a different system the files are accessible and usable. (ex. You can play music that's on it). How can I...
When you connect the Fujitsu to the Sony laptop. use disk management utility to see how the how the sony is characterizing the Fujitsu. If you can access the files on the Fujitsu from another computer, the Fujitsu is not faulty. Your connection with the Sony is the problem. Disk management utility instructions are listed below:
A menu will open
Chose "Manage"
I hope that this information is helpful, if so, please rememeber to leave positive feedback.
Thank You,
Brian
Feb 13, 2011 | Fujitsu 160GB 2.5" 7200rpm Internal Hard...
Where is sandisk repair centre in banglore? my 8 gb pen drive is not able to access by the computer and it is not getting formated
You can work at formatting you cruzer using windows disk management utility. The instructions are listed below. This may help you avoid going to the repair center. If your computer does not see the flash drive and you see no activity, the cruzer may failed. These 2 gb flash drives are really cheaper to replace than to repair in todays market. Also here is a link to Scandisk support showing directions and images refering the use of disk management.
http://kb.sandisk.com/app/answers/detail/a_id/10/sno/0
Here are the directions:
- Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
If you found this information helpful, please remember to leave positive feedback.
Thank You,
Brian
Feb 11, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My sea gate external hard drive can not open and my computer can not read it
Using the windows disk management utility. This will tell you if the hard drive is connecting to the computer or if it is a hardware problem. Sometimes, power cycling the external and restarting the computer will help. Below are the directions for using this utility:
A menu will open
Chose "Manage"
Please remember to post positive feedback if this solution was helpful. If not, please let me know and I will assist your further.
Thank You,
Brian
Jan 25, 2011 | Seagate FreeAgent Go 500 GB USB Hard Drive
CANT FIND IT ON MY COMPUTER
have u insert it? check it at first in device manager then inform is it showing or nt?
Mar 24, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Windows will not start
Hai
This could be a problem with corrupted operating system files, I request you to format you hard drive completely then reinstall the operating system you want. If you could format the complete hard drive then there is no problem with the hard drive.
This should fix the issue.
Feb 03, 2010 | Microsoft Windows XP Professional
Maxstor shared Storage II 500GB
Try mapping that drive as a network share under windows XP. This is done from "MY Computer" Map network drive. The set up your backups to back up the network drive you have created. If that does not do it then there is a contention between vista and xp as to the owner of the drive. Making the drive a mapped network drive should resolve this as neither should have ownership. Thats my best quess without knowing in detail your network setup.
Jun 27, 2007 | Maxtor Shared Storage II (S01R320) Hard...
Computers & Internet Logo
70 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
