Question about Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet dryer mod GEW9200LW0, working but not heating up
Where do i start?
  • carlalarch Mar 10, 2009
    THE MODEL NUMBER WAS GIVENwhirpool duet dryer mod GEW9200LW0, working but not heating
  • Scott Wiuff
    Scott Wiuff May 11, 2010
    what is it doing? What is the model number? It should be seen by opening the door. They are realativly easy to fix. Let me know and I'll see what we can do
    Scholar:
  • 87 Answers
If it's starting and not heating it's usually one of two things. Take off the bottom panel. 2 screws hold it in place. If you have a way to check the element with a meter or something that would be ideal. It should read about a short circuit. The other part that goes out a lot is the thermal fuse located in the front on a pipe it's long and narrow. Here is a link to show where things are in there. Let me know if you have any more questions
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=GEW9200LW0&productCategoryId=0151200&brandId=1198&modelName=DRYER
Posted on Mar 12, 2009
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
I have a whirlpool duet gew9200lw0,it will not heat. I replaced the thermistor, thermostat,termafuse and multiple other parts and still will not heat. I need help please.
You changed all these bits without establishing whether the element was faulty? Find a local appliance engineer.
Nov 15, 2014 | Dryers
G.E. WHIRLPOOL DUET DRYER MOD.# GEW9200LW0 my grandma has this dryer and the problem where having is it will start,run,get hot but takes 2 hrs to dry, vents are clean, and i put my clothes in it and it...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 27, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Whirlpool GEW9200LW0 Not heating
Hi
You need to remove the back panel first then with a multi meter the easiest way is to put the meter on continuaty test (beeps when contact is made then with the dryer switched of and unplugged put one probe on the one side of the element and the other on the other side if it beeps then your element should be ok if not one of two things (1) Your element is blown or (2) there should be a fuse around the area of the back support plate it may be a normal round fuse or a ceramic round fuse or what looks like a brown rectangular piece of plastic with a wire out each side test the fuse in the same way as you tested the element if blown replace if not then put in a element.
Jan 22, 2009 | Whirlpool GEW9200L Electric Dryer
My Whirlpool Duet Dryer is not heating up. Unit is only Two year
If it is a gas dryer. Sounds like thermal fuse. It costs about $12.95. Most appliance part stores carry it all the time. Very easy to replace. Also can be ignition switch (also cheap). If you know someone who is mechancally inclined, after removing fuse,they can run an electrical jumper cord to the two open ends. If the dryer begins drying, then it is definitely the fuse.
Go to Whirpool site and get part number and diagram to fix. Maytag repair can help at a costly figure after they order part since Whirpool bought Maytag.
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Model GEW9200LW0 Dryer will not start-Code 3E
I have a GEW9200LW0 whirlpool dryer, that displays 3E when I try and start the dryer. nothing happens,All i get is the 3E code.
Dec 08, 2007 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
237 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
