Question about Car Audio & Video
The factory radio was taken out before I purchased the car. I have an after market system I want to install. I would like to connect it through the acc on ingnition switch. I can't make out the hotwire or the ignition wire.
  • 55 Answers
Ignition wire is typically orange or yellow. The hot is always red ground is always black.
Posted on Mar 09, 2009
Installed after market radio in my 2002 buick rendevous i get power to the radio but no sound
Why you buy a harness that is factory matched from Best Buy. Could be the speakers were power amped from the factory stereo and the after market is not powering them. Would call Best Buy to confirm it.
Jun 18, 2014 | Car Audio & Video
After Market Radio Installation
Hey man, you have an amplified system. use a 70-1858 wiring harness and jump the blue/white wire from the aftermarket radio to the pink wire on the second plug. this will power on the factory amp with the aftermarket radio.
Chris-
May 04, 2013 | 2000 GMC Yukon XL
Is there a code to expand radio stations or do I have to purchase and install a band expander - iported straight from Japan 2003 Mazda atenza station wagon
you didn't say where you are.
Band expander might work; but given the costs wouldn't if they connect the same get a
Factory or after market "radio where you are and just install it?
May 31, 2011 | Car Audio & Video
What kind of wire do I need to install Infinity reference series 605cs with a JL Audio 10" sub and a Alpine Flex 2 amp? Can I use my factory head unit?
You can use the factory speaker wiring for the Infinity speakers you should purchase a amp kit which will give you everything to install the amp. See site below
http://www.sonicelectronix.com/item_18428_Raptor+ISPKBL4-BG+by+Metra.html
Well that all depends on the current audio system you have now is it just a basic or a premium factory system with a factory amp. Honestly you would get a better and cleaner sound if you change the factory head unit to a after market one which has preamp feeds and the higher the preout volt the better. Just make sure it is compatible with the amp volts input (Example 4v to 250mv) If you use the factory headunit you would have to by a high to preout adapter it connects to the exsiting radios speaker leads, but like I said before change the head unit you won't be sorry. Do not forget if you change the radio you need a radio install kit and the wiring harrness which converts the two radio plugs so you don't cut them so down the road you can remove the after market radio and just replug the factory right back in.
Apr 16, 2010 | Infinity Reference REF 605CS Car Component...
I want to change my original cd player for a pioneer
This is because you need to purchase the aftermarket-oem harness plug.This harness plugs into your original equipment radio harness and allows you to plug any aftermarket radio into the stock deck wires.After you plug the harness in you can then connect the radio wires together.Your local autoparts store or circuit city or best buy or audio express will have these radio conversion plugs.I hope I could help
Dec 24, 2009 | 2003 Ford Explorer
Factory radio main key to ignition switch
The factory radio has nothing to do with a car starting or not starting. You can install any radio that you like in your car as long as it was installed properly there will be no problem. The no start needs to be looked at but don't look at radio for cause. Would need more info on the no start to help there. You should take notes as to conditions when car won't start.
Sep 30, 2009 | 2000 Chevrolet Impala
I installed an aftermarket radio speakers sub and amps, the problem is with the radio reception. does the factory amp have to be powered on for the factory diversity antenna to work? if so how can you...
the after market stereo has a wire called antena if if u bought a carwiring kit than all the wires should bethere just connect it and make sure ur antena wire is connected too
Jun 28, 2009 | Car Audio & Video
My cd changer, radio and amp are inter connected.the owners manuel say that if all are not hooked up system will not work. i install an after market radio but cant get the factory amp to come on
Hello moemoneymood,
Since you did not specify the make and model of your aftermarket radio, I cannot pinpoint specific connection problems. Most aftermarket receivers have a "remote turn-on" lead, probably blue, but sometimes blue/white, usually terminated with a spade lug. In addition to power and ground, the amp requires this lead to be connected in order to properly operate.
Start by checking the wiring from the old receiver wiring harness and see which wires and what colors went to the stock amp. Then connect the corresponding wires from your new receiver to the amp. Some OEM receiver/amp systems had power and ground taken from the same harness, so you may need to run those separately.
Apr 11, 2009 | Car Audio & Video
Alarm system stoped working on 87 caddy fleetwood
First question , is it a FACTORY alarm or an AFTER MARKET alarm. Regardless, I haven't met an alarm yet, that protects the radio.. My guess is, that if it is an aft/market alarm, inadvertantly placed the system in the "VALET" where it doesn'i work. Let me know if you disconnected battery, and are there alarm toggle switches.
Mar 23, 2009 | 1995 Cadillac DeVille
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
