Question about Saeco VIA Venezia
I can't find user manual for Saeco Via Venezia. I
I can't find user manual for Saeco Via Venezia. It's not pulling shots like ti should. I thought it said to NOT use commerical de-scaler product. (harmful?) But I don't remember what product it recommended. Does anyone know what alternative de-scaler products there are?
    President:
  • 1,618 Answers
Do not use vinegar, but any non toxic commercial descaler can be used, as long as you remember it is a small machine use less.
Posted on Mar 09, 2009
Is it worth it to get the machine fixed if the heating element no longer works?
Saeco Via Venezia - YouTube
? 3:10
www.youtube.com/watch?v=8L8vdfMOx2g
Nov 24, 2011 - Uploaded by TheSTiGUi
I dusted off my old Saeco Via Venezia, and wanted t. ... Quick run down of my incomplete modified Saeco Via Venezia Espresso Machine ... a start temperature of ~95deg C (obviously depends on boiler water temperature etc.) ...
Jul 28, 2015 | Saeco VIA Venezia
Coffe does not come out, it starts sounding that it will then it stops
If you remove the porta filter, will water come out when you turn on the pump? If so, your porta filter is clogged and soaking it in white venigar will unclog it. To keep it from clogging, after each use, put it back on the machine and run hot water thru it until the water runs clear. (Remove grounds first)
Does water come out the steam wand?
When was the last time you ran a cleaner thru it? The Saeco de scaler cleaner is designed specifically for your machine. Purchase from Amazon for about $10.00 and use every six months.
if it still won't work,melt me know.
Feb 28, 2015 | Saeco VIA Venezia
We have broken the handle on pressurized portafilter for Saeco Via Venezia espresso machine. where can we get replacement?
I don't think the handle is sold separately. Seattlecoffeegear does sells both a bottomless and an unpressurised portafilter for the Via Venezia. Both would be considered upgraded gear vs the pressurized one.
Jan 30, 2013 | Saeco VIA Venezia
Need manual for saeco via venezia expresso
Check out this site, the pdf for the gaggia classic is similar.
Jun 28, 2010 | Saeco VIA Venezia
Saeco espresso machine Isn't pulling water at all
Can you brew a coffee? If not then the problem is the pump might be blocked.
Jun 22, 2009 | Saeco VIA Venezia
Lost a piece of the black plastic steaming wand
Check with WholeLatteLove, yes I know the only have gaggia parts, its the same thing.
May 07, 2009 | Saeco VIA Venezia
Saeco Via Venezia Cappacino Machine The black plastic sleave for the frothing arm has melted and no longer fits on - where can i get a new one? I am based in Canberra - its a Via Venizia Espresso
Contact Saeco Australia to see if they can help you.
Saeco Australia Pty Ltd
6/87 Newlands Road Reservoir
Victoria 3073
Australia
Tel.: +61 3 94624949
Fax: +61 3 94624955
E-mail: info@saeco.com.au
/Mirran
Aug 31, 2008 | Saeco VIA Venezia
Pump sounds loud and slurpy but doesn't pump
Try descaling the machine. Saeco has a suitable solution, although the user manual says 'you may use any commercially available non-toxic descaling agent.' The instructions are set out in the user manual, and are usually on the descaling agent label. It is important to descale regularly, at least every 4-6 months.
Mar 18, 2008 | Saeco VIA Venezia
Saeco VIA Venezia Logo
662 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
