Question about La Crosse Technology Wireless Thermometer WS9007UIT
Outside tempature will not display
New product, new batteries, followed instructions
New la crosse technology wind speed weather station model # CA87092 set up.wind speed and outdoor temperature showed until this morning.new batteries used yesterday in setup. what is the problem?
The instructions for your station call for a specific set up procedure. Batteries should be installed in the transmitter first with time allowed for it to initialize and begin sending data. After installing batteries in the receiver, you should see wind speed and temperature displayed. BUT, here in the real world I have a Lacrosse receiver currently displaying a balmy 67 degrees inside and a not-so-balmy - - outside. I believe the alkaline batteries used in the transmitter lose efficiency or freeze at low temperatures. Warmer weather restores the outside temperature display.
Jan 05, 2017 | La Crosse Measuring Tools & Sensors
My nextech wireless weather forcaster wont display out side temp. I have replaced the bats and held down the down arrow button
I dont have this unit but you might look for a reset button inside the battery compartment (or on the back, some times labeled).
Also, standard procedures are, remove batts. for a few minutes and follow the manuals instructions to start it up. Look for manual on internet. Also check for trouble shooting tips at manufactures web site.
You tested the "new" batteries, right? Long shot is leave batteries out over night to be sure unit is off. Try to find a reset button in manual or manufactures web site. Think about opening unit up with screw driver and look for reset. Did you follow instructions to select channel on both inside and outside units? My Weather Station has 3 chanels and I have to match them.
Nov 21, 2016 | Measuring Tools & Sensors
My La Cross Technology 9035 weather station display everything in the number 8
The instructions are specific regarding the order of battery replacement. First, the outside followed by a pause to allow the ouside unit to begin communicating. Next, the inside unit with a pause until results are displayed.
Aug 13, 2014 | Computers & Internet
Outside temp
Remove all batteries. Reinstall batteries (or new ones) in the outside unit. Install batteries in the console. DO NOT TOUCH ANYTHING! Wait until the outside temperature displays on the console. Make any adjustments necessary.
Nov 05, 2013 | Davis Instruments Davis Vantage Vue...
I followed the instructions to replace the AAA batteries, but the outside temp won't properly register.
I think yolu answered your own queistion there. Its gone faulty, probably in the logic chip. These things blow so easily and are made so cheaply- even the best of them- that when you return them under warranty they toss them in the garbage or recycling and hand you a new one. Its not repairable. Take it back or send it back. Demand a new one. A reputable dealer or company will not argue.
Mar 18, 2013 | iPhone Apps
Tempature sensor for outside not working
Car should still be under new car warranty so take it back to the dealer for replacement of the faulty part
Dec 26, 2012 | 2011 Buick Regal
Oven temp not correct
One thing you should know about a gas oven is that they do not keep a constant tempature like an electric oven does. So going by a tempature gauge in the oven can fool you. The way a gas oven works is by "average" tempature. In other words if you take the highest and lowest tempature readings and average them out you will get the actual tempature. For example let's say that you set the oven to 350. Well first it will take about 10 to 15 minutes for the oven to properly pre-heat. Once it is preheated you can listen to the gas burner and watch a tempature gauge(flook meter is best). When the gas burner shuts off the oven tempature will continue to rise. When the oven tempature stops rising then you will take that reading. Then wait for the oven burner to come back on again and watch the tempature gauge. When the tempature gets to it's lowest point and stops then take that reading. Do this several times and then take all the tempature readings and add them together then divide that number by the number of readings you took and that will give you the actual tempature. Within 5 degrees is great but anything over 10 degrees can affect your cooking. This will give you an idea if your oven is out of calibration or not.
There is a calibration procedure. The instuctions are located in the owners manual and can be found here http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-85131.PDF
Just go to the "Thermostat Adjustment" section for the proper calibration procedure.
Jul 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
Changed batteries
Also,
Sep 07, 2008 | SkyScan 86709 Atomic Wall Clock
OUTDOOR TEMPERATURE
Also,
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
La Crosse Technology Wireless Thermometer WS9007UIT Logo
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
