Instalation manual for valor flamenco unigas 111 balanced flue wall mount gas fire
Im also looking for some manufacturers instructions for a Valor Flamenco gas fire, if anyone has any could they kindly send me a copy to:
Thanksyou in advance
Posted on Nov 27, 2011
Hi there, did you mange to find a copy of the instructions for the valor flamenco unigas ii at all?? i need to replace the ignitor so would like to see a copy..
Posted on Oct 04, 2010
Valor nevada deluxe 2 gas wall heater instructions
We have two Valor Nevada2 Deluxe outside wall mounted natural gas fire heaters ( with flues ). After years of use, they require being replaced. We want similar. Please recommend the best type.
Thank you."
Jan 06, 2012 | Heating & Cooling
Valor flamenco unigas 2 fire ignites but wont stay on, assume this thermocouple problem how is thermocouple replaced
Valor uses either a Thermocouple or Thermopile, depending on the unit. In some cases, it has both. And, yes, your assumption is probably correct. Some thermocouples are a part of the Pilot Assembly, which means you have to replace entire pilot assembly. If you check you Owners Manual in the Parts Breakdown section, it will indicate if it is or not and whether you need a Thermocouple or Thermopile or both.
If you're not familiar with repairing gas fireplaces, replacing the parts listed above, can be a little challenging. Especially if you don't have the proper tools. But, before you jump on this project, try cleaning the Pilot Orifice first. You can easily do this, using canned compressed air with a straw nozzle (like you clean your computer with) by blowing out the pilot tip. And while you're at it, clean all around the pilot assembly with the canned air. If cleaning the pilot solved your problem, you're back in business. If it didn't you'll have to go the other route.
Hope this helps you solve the problem. Please be kind enough to rate my reply to you. Thanks!
Mar 24, 2011 | Heating & Cooling
Put together starter system need a diagram on a valor tropic 121 wall gas fire
You should be able to download the installer instructions on
Valors website, the information can be found here
under Trade then installer guides
alternatively new Valor Gas Fires
Jan 02, 2011 | Valor Toys
I installed the heater to the minimum distance from the ceiling due to the vent cap on the outside wall. The way I read the instructions it appeared the the end of the vent cap could not be within...
the flue is what is called a balanced flue, air in the other flue to burn inner flue is outlet gases , so you cannot just put any flue on there if is not in the makers instructions i would say no or contact the makes to be sure, how far is it from the fence
Dec 03, 2010 | Williams 1403622 Gas Compact Heater
Cannot get the pilot light to ignite on my Valor Flamenco Unigas II when the ignition knob is pressed down. Have had the ignition battery out, but the voltage seems to be correct. Fire Serial No 005 344 No...
Is the clicker making the clicking noise? If not, it is most probably the spark generator which houses the battery. The part is still available online for about £40. It did the job for me.
Oct 10, 2010 | General Heating & Cooling
Hello, I'm having problems getting a new gas fire fitted in my rental property. I have been quoted at £763. I already have a coal effect gas fire on the wall (no fire place) with a flue and obviously...
Older fires have an exhaust flue and get their air supply from the well ventilated room in which they're fitted. Balanced flue fires are the correct choice for rooms which lack sufficient fresh air ventilation. They have a flue which draws in outside air necessary for combustion whilst also acting as an exhaust for the combustion products. To work the appliance must be completely sealed so that no air is drawn from the room; the pressure of the incoming air and the pressure of the outgoing exhaust is equal so the flue is described as balanced.
The lack of a requirement for fresh air ventilation means that less energy is used; open outside vents let heat out as whilst allowing fresh air to enter.
Balanced flue appliances which exit directly through an exterior wall should cost very little more to fit than a regular appliance: the only additional cost may be in blocking up the old flue outlet and creating a new one but this rarely takes more than half an hour. A sealing collar is fitted to the outside of the flue (included in the flue kit) so there may be additional costs in hiring a ladder (or even erecting scaffolding) if you're higher than the ground floor.
Budget-level balanced flue fires typically cost between £350-£500 and the fitting charge may be fair depending upon your property, but it's also worryingly vague. A properly qualified and experienced gas fitter should be able to give you a precise quote and will already possess all of the tools needed to fit a new flue.
Also, ensure that you have your landlord's written permission to fit the new fire. If you don't then the landlord can claim that you have damaged the property and demand that you restore the property to original condition when you leave. If you get permission then you can also expect your landlord to insist that when you leave the property you do not take the new fire with you and that you supply an original copy of the gas fitter's installation certificate. Without this the landlord is within his/her rights to commission a safety inspection at your expense. Note that subsequent annual gas safety checks are required to be carried out by the landlord at his/her expense as per normal.
Oct 20, 2009 | Dryers
Heating & Cooling Logo
1,665 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
