Our model# OM99732 office max shredder got jammed and after the jam was removed the motor no longer turns on. I took out the screws on the underside and removed the top to see if anything was jammed inside, found nothing. How do we fix the motor, if that's the problem?
  • 5 more comments
  • Anonymous Mar 16, 2009
    I have the same issue.
  • Anonymous Mar 31, 2009
    After I removed the jam the shredder no longer works. Each time I go to shred somethng the overheat/overload light goes off. The manual says unplug and wait 45 min- but its been 2days now and its still messed up.
  • Anonymous Apr 13, 2009
    I, also, have the same problem
    i have the same problem, too
  • Anonymous Apr 22, 2009
    I also have the same problem and have tried everything, but no solution.
  • m4r14s Apr 26, 2009
    I've the same problem too since 3 days a go. Help.... or it's time to go to the dumpster. I bought it October 2008.
  • Anonymous May 12, 2009
    I have the same problem too. At least the company reads this blog and advises sth.
I had the same problem with the OfficeMax OM99732 and it turned out to be a blown fuse on the circuit board. The thing jammed then died. The fuse is soldered into the circuit board so if you do not know how to solder you need to find someone who does and will do it at a reasonable price. The fuse is on one of the corners of the circuit board. I went to the local radio shack and got five 3 amp fuses and an in line fuse holder for a total of 6 dollars, and installed them. Now when it overloads again I will just have to slip in one of the other fuses no soldering. There was also a cold solder joint (a poorly done solder joint) on a lead to the switch, which senses if the shredder is on its base. The lead pulled lose when I removed the cover. It was easy to re-solder but not the cause of the original problem just a sign of cheap construction.
Posted on Jun 28, 2009
    Sergeant:
  • 176 Answers
If you are brave enough to open up the shredder then unplug the power cord to remove power. then remove the cover. i dont know office max machine configuration but you have blades for shredding paper and off to the side you will have the motor and a chain or a gear system connecting to the blades try to rotate the chain or gears to see if the cutters will turn. one normal problem is gearsbreak or strip teeth motors rarely go out good luck
Posted on Aug 05, 2012
Shredder says overheat
They get a lot of paper dust in the motor area
Feb 12, 2017 | Staples Office Equipment & Supplies
Can a shredder wont goforward be repaired
Most jams are pretty much the same. First, try running the blades in REVERSE, that is done by using the on/off, selector switch.
If that does not solve the problem, Unplug the unit from the electrical, remove the top part from the basket. Pull out as much of the paper from the top and bottom that you can.
Replace the unit on the basket (make sure it is facing in the correct direction) and squirt, or lightly pour mineral oil (or machine oil, or something like WD-40) directly on the rollers and let it absorb into the remaining paper for a few minutes then try running the unit. If the motor does not come on, there is a fuse inside the machine that may need to be replaced.
Once you have solved the problem, you should oil the blades after every hour of use, it really makes it easier on the blades.
Also, there is an internal "heat switch" in the machine that will shut it down for about 90 minutes if the motor gets to hot. It is a safety factor in case you get something stuck, like a person wearing a tie, etc. After the machine has cooled down, turn the on/off switch to off and then back to on.
Jul 12, 2014 | Office Depot Ativa CX10W Shredder
Shredder will go on reverse but not forward
I have one like the one pictured. UNPLUG THE UNIT, USE GLOVES THE WHEELS ARE SHARP. Take another look at the underside see if the old paper is compacted if so, use an ice pick to pry the paper loose but be careful. Another item you will see 7 holes those are screws. Use a phillips and remove the screws to expose the working parts. Look for paper jams etc. move the wheels by hand, add a little WE40 or lite oil. Hope this helps.
Apr 09, 2014 | Fellowes P400C-2 Shredder
Shredder No Longer Does
Office shredders, even the heavy-duty ones, tend to jam up over time and have to be cleaned up to restore operation. If you have removed all jammed paper bits and still get erratic operation, the shredding process may have bent or broken some internal parts. It is not economically practical to try to repair. Better to buy a replacement.
Dec 27, 2013 | Royal Jaws Shredder
Shredder won't shred forward but works in reverse
Either the "eyes" are dirty or faulty, or the pcb has gone. Call Royal at 1-800-524-0799 for parts availability. When you get it working again only run the unit at 70% of its max rating... this provides less stress on the motor and internal parts.. the machine will last longer and you will have fewer jams.
Aug 07, 2010 | Royal 80x Shredder
Jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Sep 02, 2008 | Fellowes Powershred 480 Shredder
Paper shredder jam
Check out this video below. I think it should solve any further paper shredder jam problems.
Jul 18, 2008 | Office Equipment & Supplies
Fellowes PS-70 Shredder jam
I used needle-nose pliers and regular pliers to pull out all of the jammed paper -- it took an hour but I finally got it. I never did find a release mechanism even after I took the top apart. Thanks anyway!
Jun 13, 2008 | Fellowes PS70-2CD Shredder
Wont stop running
The auto switch is stuck. Feed more paper in it to clear it, and kick once for me. The shredder has a paper jam. You can try 3 or more sheets at one time to clear it. Also try 'paper shred oil'. You can buy it at Office Depot or Office Max.
Jul 06, 2007 | Office Depot Ativa DQ60M Shredder
1,688 people viewed this question
k24674
